Easy to make taper jig?
Forum topic by richardwootton posted 01-18-2013 10:38 PM 2984 views 0 times favorited 5 replies Add to Favorites Watch
View richardwootton's profile
richardwootton
1699 posts in 1918 days
01-18-2013 10:38 PM
Does anyone have a pretty simple plan for making a taper jig for the table saw?
Thanks,
Richard
-- Richard, Hot Springs, Ar -- Galoot In Training
5 replies so far
View Chris Moellering's profile
Chris Moellering
227 posts in 2610 days
#1 posted 01-18-2013 10:42 PM
http://www.newyankee.com/ this week’s free episode Norm goes over some of his favorite jigs, including a simple tapering jig for the table saw. He explains it in enough detail you could build from the video. Should be up until sometime Monday, that’s when they usually switch episodes.
-- Grace & peace, Chris+
View Brandon's profile
Brandon
4152 posts in 2914 days
#2 posted 01-18-2013 10:47 PM
Here’s this one:
http://www.woodsmithshop.com/download/609/taper-jig.pdf
Plus another that was posted here recently:
http://lumberjocks.com/projects/77838
-- "hold fast to that which is good"
View toolie's profile
toolie
2120 posts in 2591 days
#3 posted 01-19-2013 12:26 AM
and the simplest taper jig (sled) of all is…............................
a piece of mdf or plywood with two parallel sides that’s wider than the workpiece, and a roll of double sided tape. position the taper sled between the blade and the fence such that the sled just touches the blade. mark the taper on the workpiece. put double sided tape on the sled so it captures the workpiece but leaves the taper off cut hanging out past the blade. king of like a jig for ripping a board with no even and flat sides. works really well and it;s really cheap. can also be fabricated to whatever width/length is needed.
View JAAune's profile
JAAune
1783 posts in 2279 days
#4 posted 01-19-2013 05:11 AM
One of the most effective methods I’ve come up with so far is just to make a single runner sled and screw an angled fence to it at the appropriate angle. With a little sandpaper under the workpiece and some De-Sta-Co clamps holding it down the cut is accurate, repeatable and safe.
View Jim Finn's profile
Jim Finn
2647 posts in 2884 days
#5 posted 01-19-2013 01:43 PM
I made one similar to the woodsmith one mentioned above. I use it a lot to make tapered waste baskets and cornucopias and yes tapered table legs.
-- Website is https://craftingcouple.com/
