10 parts
« back to Woodturning forum
Forum topic by Diggerjacks posted 01-18-2013 06:20 PM 1333 views 0 times favorited 23 replies Add to Favorites Watch
View Diggerjacks's profile
Diggerjacks
2236 posts in 3107 days
01-18-2013 06:20 PM
Hello
I was looking for a technic to divide a cercle in 10 parts
Thanks for your responses
-- Diggerjack-France ---The only limit is the limit of the mind and the mind has no limit
23 replies so far
View Bricofleur's profile
Bricofleur
1440 posts in 3162 days
#1 posted 01-18-2013 06:22 PM
Hi Jack,
Use a 40 teeth saw blade and mark at each four tooth. :-)
Best,
Serge
http://atelierdubricoleur.wordpress.com
-- Learn from yesterday, work today and enjoy success tomorrow. -- http://atelierdubricoleur.wordpress.com
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6940 posts in 3403 days
#2 posted 01-18-2013 06:25 PM
Do you want equal parts?
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
Diggerjacks
#3 posted 01-18-2013 06:37 PM
Hello
Thanks for yours responses
I have a circle piece ( like a plate) on my lathe and I will make 10 holes at equal distance whatever the diamater of the piece.
Thanks
Bricofleur
#4 posted 01-18-2013 06:46 PM
So you will end up with an indexing wheel ? That will be handy !
Best,
Serge
View helluvawreck's profile
helluvawreck
30765 posts in 2835 days
#5 posted 01-18-2013 06:47 PM
Draw your circle. Draw a diameter through the center. Use the line and a protractor to draw a second line through the center to the circle at 36 degrees to the first line. Set the points of your dividers to the two points where the lines intersect the circle. This setting should be very close depending on how accurate your lines were. Walk your dividers around your circle very lightly to check the setting. If it’s close enough for your needs your ready to go. If not then adjust the dividers ever so slightly and check again. Once set you’re ready to go.
helluvawreck aka Charles
Diggerjacks
#6 posted 01-18-2013 07:14 PM
Hello
Thanks to all for your responses
I will make an indexing wheel
I was thinking there was another solution but …
Another project ==> Another jig
Thanks
View rance's profile
rance
4255 posts in 3129 days
#7 posted 01-18-2013 07:19 PM
I like the 40 teeth saw blade idea. Personally, I’d probably draw it in SketchUp and print it out. You can also search for segmented circles on the web and print those out.
View bandit571's profile
bandit571
19761 posts in 2652 days
#8 posted 01-18-2013 08:12 PM
360 degrees in a circle , divide by 10=
View StumpyNubs's profile
StumpyNubs
7579 posts in 2769 days
#9 posted 01-18-2013 11:20 PM
When I get a pizza they usually just divide it into 10 random parts. One piece is half the pizza, another piece is just a little sliver… GREAT! Now I have to order a pizza! THANKS A LOT DIGGER!!!!!!
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
View Roger's profile
Roger
20923 posts in 2773 days
#10 posted 01-18-2013 11:35 PM
I had an answer, then, I seen Stumps response, now I’m think a cold one to go with that pizza…. I’ll take the sliver…..I gotta keep up my image….. :)
View Wildwood's profile
Wildwood
2300 posts in 2103 days
#11 posted 01-19-2013 11:24 AM
Do not see 10 segments at link, but take a look anyway if find something can use just print it off an glue to your wood, plastic, or steel.
http://www.smithart.us/download.htm
-- Bill
View kizerpea's profile
kizerpea
774 posts in 2336 days
#12 posted 01-19-2013 01:45 PM
10-sides decagon
center angle 36 deg
miter 72 deg
infomation sourse THE BEALL TOOL CO,,,,NEWARK OHIO..
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
Bricofleur
#13 posted 01-19-2013 03:57 PM
@Wildwood: Thanks for the link. 10 segments is not shown perhaps because you can use the 20 and skip one after the other to get the 10.
Best,
Serge
Diggerjacks
#14 posted 01-19-2013 05:59 PM
Hello
Thanks a lot to everybody for your responses
To StumpyNubs and Roger : ” Bon app├ętit”
To Wildwood : Thanks for the link
I will print a lot circular graph for a lot of futurs ideas.
To Bricofleur : Thanks for the interest of this blog and I will use a 20 segments / 2
Thanks
Diggerjacks
#15 posted 01-19-2013 06:56 PM
Hello
With the link of wildwood and corel draw I have made my circular graph
I can mail you a pdf circular graph 10 segments for who want
