Help! Major mistake!
Forum topic by Beginner513 posted 120 days ago 607 views 0 times favorited 18 replies Add to Favorites Watch
View Beginner513's profile
Beginner513
3 posts in 120 days
120 days ago
This is my first major home
project—I just started refinishing my kitchen cabinets (original to the ‘55 house). I managed to get one cabinet successfully stripped and sanded, but boy did I mess up the second one. I tried sanding with the grain, once I realized my mistake, and it only made it worse. I feel like the Cat in the Hat right about now. Any suggestions for how to fix this major mistake?
18 replies so far
View Kelby's profile
Kelby
116 posts in 576 days
#1 posted 120 days ago
Is this the door of the cabinet, or part of the box?
-- Kelby
View Purrmaster's profile
Purrmaster
401 posts in 258 days
#2 posted 120 days ago
Are the cross grain scratches too deep for a random orbital sander to sand them out? Could you use a belt sander with the grain to sand them out?
Beginner513
3 posts in 120 days
#3 posted 120 days ago
It is a cabinet door front. There was some stubborn paint in that spot. At least the paint is gone. I have a Black&Decker Mouse sander that the guy at my hardware store suggested for the job. Used 80 grit. Could that be the problem?
Beginner513
3 posts in 120 days
#4 posted 120 days ago
The scratches don’t seem too deep.
View ellen35's profile
ellen35
2438 posts in 1597 days
#5 posted 120 days ago
80 grit??? Seems very coarse. start with a higher grit and work your way up. I think the 80 was just too much for the wood.
View Wdwerker's profile
Wdwerker
303 posts in 398 days
#6 posted 120 days ago
You sanded through the veneer. Not much you can do, replace the door, re-veneer , or try to hide it with dark stain.
-- Fine Custom Woodwork since 1978
View crank49's profile
crank49
2276 posts in 1136 days
#7 posted 120 days ago
You might have better luck going forward by stripping first, then light sanding with fine grit.
Are the doors plain or raised panel?
You need a good scraper also.
I like to use the “Red Devil” handled scraper to pull the gunk out of corners when stripping.
In terms of fixing the cross grain scratches, if those were plain plywood doors (typical of 1950s) you might be able to sand and scrap with the grain and fix it. Plywood of the 50s was much higher quality with thicker veneers than the stuff available today.
Sorry if there are pictures, my work computer won’t display pictures on this site, so I am responding in the blind.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View Mike53E's profile
Mike53E
12 posts in 369 days
#8 posted 120 days ago
The best way to remove paint quickly is with a heat gun and a putty knife. Hit it with the sander or a card scraper to finish up. The 20$ you will spend for a heat gun is worth the hours of time you will save.
View Bogeyguy's profile
Bogeyguy
127 posts in 233 days
#9 posted 120 days ago
Looks like you sanded through the veneer. If that’s the case that surface is shot. Not sure what part of the cabinet it is. Can you hide it somewhere? Cover it with a piece of veneer?? I don’t think your going to be able to make that spot look good with a stain or other type of finish.
View huff's profile
huff
2549 posts in 1450 days
#10 posted 120 days ago
From the picture, it looks like you sanded through the veneer. Looks like the more you sanded the worse it got. If so, you do have a problem. No staining is going to hide that. The sub layer will always stain differently and of course the grain is running the opposite direction from the veneer. You may need to reveneer that door or make another. Going to be tough to match no matter what you do…...............except repaint.
-- John @ http://www.thehuffordfurnituregroup.com
View Straightbowed's profile
Straightbowed
576 posts in 463 days
#11 posted 120 days ago
I know your pain I was goin to sand my cabs down and hit the veneer of course I really thought they were solid so I painted them
-- Stevo, work in tha city woodshop in the country
Straightbowed
#12 posted 120 days ago
paint cabs with a super good grade of paint they will look great
View dhazelton's profile
dhazelton
828 posts in 462 days
#13 posted 120 days ago
How do you plan on finishing them? If you plan on painting you can just use bondo there and you won’t see the gouging. If you plan on stain and varnish you may decide to just make a new door (you won’t sand out that round spot with the two screw holes anyway). Most site built 1950s cabinet doors were just plywood so it should be simple to duplicate. You’ll have to be creative with the stain to match the old work. Or chuck it and make that cabinet open faced if it’s an upper and that look works for you.
View Marcus's profile
Marcus
510 posts in 185 days
#14 posted 120 days ago
Another vote for “that door is done”. Maybe consider replacing the panel with glass and do the same to a matching door? I’ve seen this look in a couple kitchens where they have just one cupboard with glass doors, looked really sharp.
View bondogaposis's profile
bondogaposis
1237 posts in 516 days
#15 posted 120 days ago
Make a new door or paint.
-- Bondo Gaposis
