Walnut Table Top Question
Forum topic by richardwootton posted 01-18-2013 09:17 AM 1891 views 0 times favorited 22 replies Add to Favorites Watch
View richardwootton's profile
richardwootton
1699 posts in 1979 days
01-18-2013 09:17 AM
Hello everyone,
This is my first post here at Lumber Jocks, but I’ve been reading the forums for a while. Here are the beginnings of my new table. This is a photo of the table top I glued up on Monday. I thought the figured walnut was really pretty and worth sharing. The white strip is just a 1/2” piece of poplar (because I didn’t have any Maple) that I thought added a nice visual design element. Let me know what you guys think.
However, someone on another forum suggested that the dark walnut sanding dust might contaminate the poplar. Does any one have any experience with a similar situation? Or do you have any suggestions on how to prevent any contamination? Any info is really appreciated.
Thanks,
Richard
-- Richard, Hot Springs, Ar -- Galoot In Training
22 replies so far
View Kelby's profile
Kelby
134 posts in 2435 days
#1 posted 01-18-2013 09:41 AM
The problem happens when the lighter wood is porous, in which case the sanding dust from the darker wood gets into the pores of the lighter wood and thus “contaminates” it.
I don’t use poplar, so I can’t say whether it is porous enough to cause problems. Usually, people use maple as a light contrasting wood with walnut, and maple is not porous so it does not create a problem.
If you are concerned, there are a few options.
One is to cut out the poplar and replace it with maple. :)
Two is to put a coat of shellac on the poplar while it is “uncontaminated”, and that should provide pretty good protection against the walnut sanding dust.
Three—- and this is what I would do—is sand the top until you are happy with it, then use a card scraper to scrape the poplar and surrounding area until it’s as fresh and clean as you want it. Then apply the finish.
-- Kelby
View Lee Barker's profile
Lee Barker
2170 posts in 2874 days
#2 posted 01-18-2013 04:40 PM
Poplar can be annoyingly soft, Richard. I think finishing is going to be frustrating not only for the contamination potential noted above, but also because it just doesn’t work up like walnut.
I don’t think it’s unworkable, I’d just like you to be prepared for what may be less than optimal results. In either case, there’s a whole lot of learning going on here, and that’s what it’s all about in my book.
Kindly,
16275 posts in 4242 days
#3 posted 01-18-2013 04:50 PM
I sort of agree with Lee. Work with it and learn from it.
I don’t think contamination will be a huge problem with those two wood types. One think I have found that works pretty well is to apply a shop vac nozzle to the lighter wood after sanding. That will pull most of the darker dust right out.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3182 days
#4 posted 01-18-2013 04:52 PM
I think Kelby nailed it. If this were porous like white oak, you’d have an issue with sanding dust getting in the pores. Otherwise, you might be safe. I did this recently with ebony inlays in QSWO and you have to be careful to work the ebony mostly BEFORE it is inlayed for this reason.
Poplar, though softer, works a lot like maple from that standpoint…and we’ve all done a bunch of walnut/maple pieces without much issue.
-- jay, www.allaboutastro.com
richardwootton
#5 posted 01-18-2013 04:53 PM
Thanks for the input guys. I’ve got to go back to our local hardwoods store this weekend and get the maple for the aprons so I might just go ahead and get a little extra in case the poplar doesn’t end up working out.
richardwootton
#6 posted 01-18-2013 05:52 PM
I talked to my lumber guy and he has some curly and quilted soft Maple. I’m guessing that’ll be a better option. I wish I’d have thought of this before I did my glue up. Live and learn!
richardwootton
#7 posted 01-19-2013 08:38 PM
I picked up some nice curly maple today for the aprons so if the Poplar does become contaminated too badly then I’ll just cut it out and replace it with the maple.
View USMCSergeant's profile
USMCSergeant
28 posts in 1979 days
#8 posted 01-22-2013 06:12 AM
I hope you post a pic of the results. The movement in the walnut is beautiful!
View Marcus's profile
Marcus
1163 posts in 2043 days
#9 posted 01-22-2013 01:53 PM
Hey Richard, I was hoping to see an update too. Post pics when available.
View dhazelton's profile
dhazelton
2771 posts in 2320 days
#10 posted 01-22-2013 02:14 PM
I agree with the point about it being soft. If a few dents in the poplar strip down the road will bother you in the future I’d replace it with maple now. If not then forge ahead.
richardwootton
#11 posted 01-22-2013 07:15 PM
Well I decided to go ahead and rip the poplar strip out and use some beautiful curly maple instead. I got sidetracked rough cutting my aprons, squaring my legs, and stabilizing/filling a couple of knots in the Walnut with a 2-part epoxy that I didn’t get around to regluing the top! I’ll post a picture or two of the maple a little later on though.
richardwootton
#12 posted 01-22-2013 09:45 PM
Here’s a picture of one of the Curly Maple boards I bought. I can’t wait to see this finished.
richardwootton
#13 posted 01-22-2013 09:45 PM
Unfortunately the figure doesn’t show up quite as well in the photo as it does in person.
View nwbusa's profile
nwbusa
1021 posts in 2310 days
#14 posted 01-22-2013 10:07 PM
Curly maple… gotta love that stuff!
-- John, BC, Canada
richardwootton
#15 posted 01-22-2013 11:11 PM
I know it! This is the first time I have ever worked with it, but I sure am glad I found some one who carries a lot of nice clear curly.
