Varying grades of MDF?
Forum topic by PRGDesigns posted 01-18-2013 03:53 AM 18381 views 0 times favorited 15 replies Add to Favorites Watch
View PRGDesigns's profile
PRGDesigns
237 posts in 2313 days
01-18-2013 03:53 AM
Topic tags/keywords: question router milling modern
Are there differing grades of MDF? I had some leftover MDF from a project several years back and it was significantly different than another piece of MDF from a different project. I don’t recall where I purchased either piece from, since I moved a lot during the time period of those previous projects. One of the pieces appeared to have coarser particles in it and cut much smoother than the other piece. It was also significantly harder/denser than the other pieces and was more of a yellow color versus the pale brown of most of the MDF I am familiar with. Any help is always appreciated. Thanks in advance for any consideration you can give this matter.
-- They call me Mr. Silly
15 replies so far
View MonteCristo's profile
MonteCristo
2099 posts in 2189 days
#1 posted 01-18-2013 04:50 AM
Not sure but I would say that there likely are. There certainly are different qualities of particle board and some of the really dense ones look a lot like MDF.
View Loren's profile
10401 posts in 3648 days
#2 posted 01-18-2013 05:00 AM
Yes, it varies. If you want the best stuff, go to a
commercial plywood dealer.
People got freaky about the formaldehyde in
and these days you can get it without. I think
Home Depot is selling the stuff now. There are
also various densities of MDF. It used to be all
real heavy (90 lbs per 3/4” 64 sq. ft) but it seems
like it doesn’t always weigh so much these days.
I have bought “ultralight” MDF and don’t recommend
it for unsupported spans or even frameless carcase
parts.
View Wdwerker's profile
Wdwerker
333 posts in 2233 days
#3 posted 01-18-2013 05:08 AM
Oh yes! There are different grades. There is HDF high density fiberboard and lots of varying qualities in between. We sprayed some MDF scraps the other day to make some new faces for toekicks. Half of them turned out fine, but half of them took 3 or 4 more coats . They were less dense and the face would not smooth out. This is why I usually do not use MDF. But in this economy if the job calls for it, why argue?
-- Fine Custom Woodwork since 1978
View Harry Montana's profile
Harry Montana
46 posts in 1995 days
#4 posted 01-18-2013 08:51 PM
absolutely , it differs on the glue and the substance. Some Chinese crap is known to warp and twist and glue is only good for a limited timeframe
-- With regards from Harry Montana http://www.hardydeck.com
View bondogaposis's profile (online now)
bondogaposis
4727 posts in 2351 days
#5 posted 01-18-2013 09:34 PM
The stuff varies depending on who makes it, each plant has their own proprietary methods.
-- Bondo Gaposis
View Dutchy's profile
Dutchy
2938 posts in 2169 days
#6 posted 01-18-2013 09:44 PM
Maybe this will help you (MDF Wikipedia)
-- https://dutchypatterns.com/
View saucer's profile
saucer
61 posts in 2947 days
#7 posted 01-18-2013 09:57 PM
There is even a outdoor grade now..
-- It has been deemed bad for you hence there for it is illegal.
View JAAune's profile
JAAune
1799 posts in 2317 days
#8 posted 01-19-2013 05:55 AM
I’m using one of the outdoor grades now for cabinets that will have sinks installed. This particular product is called Extira and is favored by sign-makers since it’s 100% waterproof. I’ve had a cutoff sitting in a container of water for several days and it’s not affected at all.
I’ve used the ultra-light stuff mentioned by Loren and while it’s a high quality product made to exacting specs, I don’t care for it since it’s very soft. It’s susceptible to dents even after veneering. I can see it being useful for large panels that will be kept away from traffic but I’ll not use it again for anything like a table top.
View MrRon's profile
MrRon
4771 posts in 3244 days
#9 posted 01-19-2013 04:57 PM
Are you referring to MDO, which is a plywood used by sign makers?
JAAune
#10 posted 01-19-2013 05:27 PM
No. This stuff is not MDO. It’s MDF all the way through and can be carved to any depth without sacrificing the waterproof integrity.
404 - Not Found
2544 posts in 2969 days
#11 posted 01-19-2013 05:41 PM
Quality varies depending on where you go. When it comes to ‘standard’ mdf, you get what you pay for. I don’t mind paying a few extra euro for a sheet that will paint better than a real cheap one.
There are moisture resistant and flame retardent sheets, as well as deep routing grade which has a deeper higher density layer.
PRGDesigns
#12 posted 10-05-2013 06:00 AM
Per Loren’s suggestion, I visited a commercial plywood dealer here in the DFW area, Central Hardwoods. They offer two qualities of MDF, a “double refined” premium Plum Creek MDF and a standard MDF. The “double refined” Plum Creek MDF is superior to any other MDF from HD or Lowes, even though HD and Lowes advertise their MDF as “premium”. I have used the “premium” MDF from Lowes in the past because they are much closer than Central Hardwood, but I have now switched to strictly buying the “double refined” MDF from Central Hardwoods. My CNC bits, same type, same vendor, same batch, last 4 times longer in the “double refined” MDF as the “premium” MDF from Lowes. The dust is much finer and more consistent with the “double refined” MDF than the coarse and inconsistent dust from the “premium” MDF from Lowes. The “double refined” MDF also finishes better, has less tear out, and has a smoother factory finish. Thanks to everyone who commented.
View Loco's profile
Loco
210 posts in 1749 days
#13 posted 10-05-2013 08:52 AM
You guys actually spend money on that crap ? LOL.
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
View lateralus819's profile
lateralus819
2241 posts in 1890 days
#14 posted 10-05-2013 12:27 PM
MDF is terrible. Extremely heavy (extira is ungodly heavy, try handling a 1” thick sheet 4×8).
At work we use MDF a LOT. As far as the extira, its okay, try soaking it in water then letting it dry out and repeat. It warps like crazy. Leaving it submerged is one thing. If it’s out and exposed to the sun it changes shape quite easily.
JAAune
#15 posted 10-05-2013 02:28 PM
The job we’re about to deliver next week called for a paint-grade waterproof base and toe kick. It also required 10 foot long pieces and we had to buy a 192”x48”x3/4” sheet to get that. Talk about heavy. We had three people just to get it off the truck.
I don’t see warping being a problem where we’re using the Extira. Cabinet boxes under sinks and toe kicks in basements are the applications where we’ve used that product.
