Brass rivets in tool handles (how is it done)
Forum topic by Emma Walker posted 01-18-2013 02:59 AM 14726 views 1 time favorited 28 replies Add to Favorites Watch
View Emma Walker's profile
Emma Walker
560 posts in 2138 days
01-18-2013 02:59 AM
I want to make carving knives from some surgical blades that got ay an auction. I need to know how brass rivets are set. Are they just peened with a hammer? If so what is the technique/best way to do this?
-- I'm a twisted 2x4 in a pile of straight lumber.
28 replies so far
View TheCook's profile
TheCook
39 posts in 2148 days
#1 posted 01-18-2013 03:02 AM
Drill a hole, stick some brass rod in, whack it with a hammer.
View lwllms's profile
lwllms
555 posts in 3309 days
#2 posted 01-18-2013 03:05 AM
Search “knife rivets brass” on Google or what ever search engine you prefer.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2559 days
#3 posted 01-18-2013 03:12 AM
Unless you have a super-accurate hammering technique (I don’t), use a drift or other form of punch. A small piece of steel rod the same diameter as the brass will work, too. It just avoids marring or possibly splitting the wood. Also, use something very hard (well, harder than brass) to back the knife when you peen it.
Epoxying them in place also works.
-- Mark Kornell, Kornell Wood Design
View Brian Strothcamp's profile
Brian Strothcamp
111 posts in 2721 days
#4 posted 01-18-2013 03:16 AM
In the good ol days… thats what the ball-peen hammer was for… I use a punch of proper size with one firm wack… best if done on a large anvil (you need something very solid or you will be cussin)
you always leave them proud… then sand or machine off the mushroom
View MichaelR's profile
MichaelR
42 posts in 2457 days
#5 posted 01-18-2013 03:17 AM
If you’re doing just a couple, a brass rod and a small ball peen hammer is cost effective. Search for “cutler rivets” for the kind you find on kitchen knifes. They come in a variety of sizes.
View lumberjoe's profile
lumberjoe
2899 posts in 2276 days
#6 posted 01-18-2013 03:17 AM
I treat them exactly like dowels. The only exception is I drive them in with a completely flat hammer to avoid rounding them over. Leave them proud on both sides and sand them down. Brass sands really easily, but harder than the surrounding wood. It’s easy to remove more wood than brass, so take it easy with the sanding and finish by hand.
A little epoxy keeps them in there for good
Emma Walker
#7 posted 01-18-2013 04:13 AM
I’m thinking maybe counter sink the brass rivet just a bit and use a punch with a wider dynamiter than the counter sink to mushroom the rivet in a uniform radius.
View madts's profile
madts
1862 posts in 2368 days
#8 posted 01-18-2013 04:30 AM
I drill a hole the same size as the rod. Then use a lot of epoxy. Has work well for me.
-- Thor and Odin are still the greatest of Gods.
Emma Walker
#9 posted 01-18-2013 04:37 AM
madts,
With no peening at all?
View bondogaposis's profile
bondogaposis
4769 posts in 2379 days
#10 posted 01-18-2013 05:38 AM
Make the brass pins slightly proud on both sides. Place on a solid surface preferably steel and give a sharp rap w/ hammer. Then sand so the pins are flush. No need for a countersink.
-- Bondo Gaposis
Emma Walker
#11 posted 01-18-2013 06:03 AM
bondogaposis,
What do you mean by proud?
View mtenterprises's profile
mtenterprises
933 posts in 2721 days
#12 posted 01-18-2013 11:28 AM
Cutterly rivits – Two-Piece Press-Fit Tubular Rivets see McMaster-Carr PN 96082A100 – http://www.mcmaster.com/#brass-rivets/=l35fqg- Scroll to the bottom.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View elingeniero's profile
elingeniero
25 posts in 2137 days
#13 posted 01-18-2013 11:55 AM
If this wasn’t 2 sided, I’d just use screws and router the slots off. Perhaps there’s brass hardware, such that you can do so on 2 sides.
View racerglen's profile
racerglen
3112 posts in 2808 days
#14 posted 01-18-2013 12:01 PM
Emma, “proud”..he means sticking up/out a bit..
-- Glen, B.C. Canada
mtenterprises
#15 posted 01-18-2013 08:47 PM
See my previous post.
MIKE
showing 1 through 15 of 28 replies
