Jet air cleaner AFS 1000B pre filters
Forum topic by BamaCummins posted 446 days ago 1026 views 0 times favorited 11 replies Add to Favorites Watch
View BamaCummins's profile
BamaCummins
54 posts in 473 days
446 days ago
Anybody tried retrofitting a REAL 12×24 filter for this unit? Although the JET filter says 12×24 it is actually slightly smaller. Hate to buy filters that cost 3 times as much as I can buy at the hardware store. JET really boogered us on this one, they want to sell their filters.
-- "I don't know, we haven't played Alabama yet." -- Vince Lombardi after being asked what it felt like to be the greatest football team in the world just after winning the '66 Super Bowl.
View DaveH's profile
DaveH
372 posts in 675 days
446 days ago
I have the same problem with my delta. At some point I’ll take the time to solve the problem.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
View John Gray's profile
John Gray
1754 posts in 782 days
446 days ago
Thanks for the post I’m in the same dilemma with a similar Grizzly G0572 Hanging Air Filter w/ Remote. Looking forward to posts about fixes.
BamaCummins
444 days ago
Measured my filter and it is 23 1/2×11 1/2, thanks JET for making this a problem.
View PurpLev's profile
PurpLev
2762 posts in 545 days
444 days ago
I am sure Jet/Delta/Grizzly didn’t make this to create a problem- they made it to MAKE MONEY ;)
as far as they are all concerned – there is no problem here… you have an air filter -and they have the filters that fit it for you… isn’t that just picture perfect?
proprietary …. gotta love that concept… same with some other green brands that you can only fit their blades, and hoses to them… kinda $ucks.
View cbMerlin's profile
cbMerlin
31 posts in 317 days
317 days ago
I found “Endust” filters at my local Lowes 3 for $6.97 that fit my Jet. They are 12×24 but measure 11.5×23.5. They fit perfectly and seem to work very well. Passed it along to my brother for his shop, he’s pleased as well. They are Merv 6 for what that’s worth. Can’t find the micron rating. I change them rather frequently when I do a lot of sanding but at a couple bucks each it’s not too bad.
-- Sawdust looks better in the garage than cars, explain that to your wife!
BamaCummins
317 days ago
Thanks for the information, I’ll try to get some.
View tenontim's profile
tenontim
1319 posts in 641 days
317 days ago
I have a Delta, which is the same size. I found that if I bent the lower lip of the filter holder out, parallel with the bottom of the unit, the after market filters would fit.
-- Tim -- http://tmuli.com
View dhg's profile
dhg
148 posts in 609 days
317 days ago
Good timing for me on this thread as I just bought the Jet 1000B last friday and hoped that a good furnace would fit. (Thanks for the info cbMerlin)
My problem at the moment is trying to figure out where to mount it. I have an 8’ ceiling in my shop with the main I-beam running down the middle of it. it i mount the unit to the ceiling i feel that the exhaust air wouldn’t circulate very well. My shop is 25’ x 25’. I would have to wear a hardhat if i mounted it below the beam anywhere in the shop! Currently it’s on a cart that I can roll around where i want it. It might stay there unless you guys have some ideas.
-- Talent on Loan from God - Rush Limbaugh ----------www.genesiswoodworks.com----------
25803 posts in 1297 days
317 days ago
I attached mine on the wall. With the bottom surface tight to the wall. The instructions stated that way to mount it was OK.
cbMerlin
316 days ago
dhg – The guy at Workwerks here in Columbus, Ohio suggested I mount it close to my wall so it creates almost a tornado effect in my shop with the air movement. I’m wondering if you did that at one end of your I-beam, close to the wall, if you could forego the hard hat. It might be out of the way enough not to cause you a problem. I’d probably still hang something of the corners, my bald head doesn’t seem to heal as fast as others, that’s why I always wear a ball cap in my shop just in case. If you mounted it like Karson, it would be even further out of the way. On another note; I have a 30,000 Btu gas heater heater installed on one wall (complete with carbon monoxide detector w/led read out – safety first). I used to have cold spots across the shop from the heater as well as very low (4-5 PPM) on the detector. Ever since I installed air cleaner the circulation has eliminated the cold spots and my dectector reads 0. Nice side benefit!
View dhg's profile
dhg
316 days ago
I’ll look into both suggestions. thanks for the input.
Karson, i’m assuming that you have the exhaust pointed toward the floor. How far from the ceiling did you mount it?
