Framing nail guns
Forum topic by lieutenantdan posted 01-16-2013 07:11 PM 1431 views 0 times favorited 15 replies Add to Favorites Watch
View lieutenantdan's profile
176 posts in 2238 days
01-16-2013 07:11 PM
Looking for some recommendations on framing nail guns. Looking at buying something inbetween a Yugo and a Cadillac. Up to 3.25 inch nail capability and pneumatic. Will not be using professionally. Thanks in advance for your feedback.
lieutenant dan
-- "Of all the things I have lost in life, I miss my mind the most."
15 replies so far
View Tennessee's profile
2808 posts in 2447 days
#1 posted 01-16-2013 07:42 PM
View toolie's profile
2116 posts in 2561 days
#2 posted 01-16-2013 07:43 PM
i have a PC full head 350. cost ~ $200. if i were doing it today, i’d go harbor freight for an occasional user.
-- there's a solution to every just have to be willing to find it.
View nwbusa's profile
1021 posts in 2219 days
#3 posted 01-16-2013 07:44 PM
+1 on the Bostitch.
-- John, BC, Canada
View MT_Stringer's profile
3160 posts in 3163 days
#4 posted 01-16-2013 07:47 PM
I have had the HF model for several years. Used it to build a 2×4 frame for a work bench and several privacy fences. Has worked OK. Pretty good buy for a homeowner-occasional use. A friend is using it to replace a fence now.
View MrRon's profile
4672 posts in 3176 days
#5 posted 01-16-2013 08:32 PM
I have several Bostitch guns. For $80 for a HF gun, you are taking a chance. It may work fine or it may not. If it doesn’t, you are out $80. I think it’s better to go with Bostitch, PC, Hitachi or Paslode. These are quality guns you won’t have to worry about. If a HF gun quits, it’s basically a throw away.
View crank49's profile
4030 posts in 2903 days
#6 posted 01-16-2013 08:41 PM
”It may work fine or it may not. If it doesn’t, you are out $80.”
Maybe not. HF has a no questions asked return policy. I never had a problem getting them to exchange something or refund my money.
View frosty50's profile
46 posts in 2280 days
#7 posted 01-16-2013 08:45 PM
Another option is Senco guns, they have beed a leading manufacture of pnuematic nailers and staplers for years. I have several different ones for different applications and have been very happy with them, would take them of PC or Paslode any day. Some of my guns are 20+ years in age and get a lot of use.
-- frosty
View Drew's profile
348 posts in 3032 days
#8 posted 01-16-2013 08:54 PM
Bostitch is a good gun for the price, will need regular maintenance.
I would recommend the Paslode 350.... This is the best framer I have ever used, and running my own crew for years…. I have used plenty.
With that said, The Bostitch and even the Porter Cable are pretty good for light duty
Must also add that as much as I loved Senco in the 90’s I’m not much of a fan anymore…. Especially their framers.
View Gshepherd's profile
1727 posts in 2134 days
#9 posted 01-16-2013 10:28 PM
I use a Hitatchi NR83a and it has been a real work horse. No problems at all and the reviews on it are top of the line.
-- What we do in life will Echo through Eternity........
View guitchess's profile
85 posts in 3641 days
#10 posted 01-17-2013 01:51 AM
For occasional use and if a little more weight is not an issue, the Harbor Freight guns are a very good, cheap option. Wait for a coupon and get one for $50-$60. I used two for a year with my professional framing crew while waiting for parts to repair my Bostich guns.
If you want to spend a little more to get a lot more, I would suggest the consumer level Hitachi, $179-$199. They are much lighter, durable, and more efficiently use the air.
As for clipped or full round head, I prefer and suggest the full round head. While these guns do not hold as many nails, the installed nails have slightly more holding power, and in some parts of the country, clipped heads will not pass code.
#11 posted 01-17-2013 02:23 AM
One other thought on the subject; be sure the nails to fit your gun are available locally.
The angle of the magazine and the method of collation (paper strip or welded wire or plastic) and the type head (full or clipped or offset full) all combine to make it difficult for retailers to stock the styles for every gun out there.
As a result, they often only stock nails for the guns they sell.
May not be a problem if you’re in a large city, but out here in fly-over land and in small towns it’s a big problem.
View jdon88's profile
19 posts in 2585 days
#12 posted 01-17-2013 05:23 AM
I have the HF model posted by Tennessee, got it for $60. with coupon. Nails available at HD or Lowes. I’ve run about 500 3” framing nails thru it with no issues.
#13 posted 01-17-2013 06:39 AM
I have the HF 6-in-1 framing gun. Can be set to three different angles and use clipped or full head nails.
I got that specefically because I wanted to be able to get nails from anywhere.
Not sure if they still sell that model, but it’s handy.
View Trevor Roth's profile
Trevor Roth
86 posts in 2038 days
#14 posted 01-17-2013 07:03 AM
I have a senco sn901 and it has been great.
View bladedust's profile
204 posts in 2199 days
#15 posted 01-17-2013 07:20 AM
Interesting timing; I was just about to put up a brand new in the box Hitachi NR83a for sale. Bought it some time ago with dreams of grand builds and never even took it out of the box.
-- ok, is it cut once measure twice, cut twice measure once???? I know....I'll just keep cutting until it's long enough.
