| Forum topic by ryanjared | posted 122 days ago | 361 views | 0 times favorited | 2 replies | ![]() |
122 days ago |
i am looking at moving a buillding to my place that is 27×32 and weighs roughly 14000lbs. how many 18’ 2×6’s screwed together to make a 27’ board should i use to carry the load of the building on a semi trailer? |
2 replies so far
#1 posted 122 days ago |
If we’re going to try to engineer a solution, I think we need to know a little bit more about how the weight will be distributed across the resulting beam, how the beam will be supported, and (here’ s the difficult part) what dynamic loads will be placed on the beam in the process of moving it. And how much flex the building can withstand, because flex strength and breaking strength are vastly different. I mean you can plug numbers in to the AWC wood span calculator all day, and 7 tons isn’t that much weight, but there’s a lot of assumptions that’d have to be made here to figure anything out. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
#2 posted 122 days ago |
Are you talking about moving it down a public roadway? If so, you had best check on permits to do so. If you do it without you will be responsible for any damage done to the road, the right of way or the private property boardering the movement. That also means you aren’t going to use a span of 2X6 to move it, you’ll need a real company with I-beams and dollies. The good part of this is that you could take the building apart and as long as the widest part is no wider than 102” on a main road, you should be fine. -- Improvise.... Adapt...... Overcome! |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3542 |
15752 |
Hand Tools
2028 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
