Gluing Lego plates to plywood
Forum topic by plang posted 01-15-2013 05:10 PM 6666 views 0 times favorited 6 replies Add to Favorites Watch
View plang's profile
plang
117 posts in 3595 days
01-15-2013 05:10 PM
Just would like to know what glue would be best for gluing Lego plates to plywood. Thanks
View MrsN's profile
MrsN
987 posts in 3766 days
#1 posted 01-15-2013 05:13 PM
I used a quick setting epoxy when I made my lego table.
also, a quick tip.
If you are gluing a few pieces to the board with spaces in between. build a bridge from legos to get the spacing right so you can connect them later with a tower if you want.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3399 days
#2 posted 01-15-2013 05:14 PM
Contact cement?
-- jay, www.allaboutastro.com
View MrRon's profile
MrRon
5277 posts in 3484 days
#3 posted 01-15-2013 05:43 PM
Hot glue.
View pudtiny's profile
pudtiny
21 posts in 2202 days
#4 posted 01-15-2013 08:01 PM
Double sided carpet tape or hot glue
View ksSlim's profile
ksSlim
1290 posts in 3130 days
#5 posted 01-15-2013 08:45 PM
Dble sided tape. Removable when a better design becomes apparent.
design usually changes every 2 years advancing in concert with budding engineers.
-- Sawdust and shavings are therapeutic
View Chris99z71's profile
Chris99z71
1 post in 1174 days
#6 posted 11-05-2015 05:42 AM
Lego plates (all Legos actuallu) are made from ABS plastic, as are plastic shower surround materials. Buy a caulk tube of shower surround adhesive (I have used loctite power grab from Home Depot $5). Scuff the back of the lego plates with some sandpaper and apply the adhesive with a fine notched trowel and slap it on your wood ;) Gently press any lumps out. To date I’ve made 4 lego tables like this and it works wonderfully.
