How can I salvage a green wood check?
Forum topic by LaPala posted 127 days ago 440 views 0 times favorited 6 replies Add to Favorites Watch
View LaPala's profile
LaPala
16 posts in 165 days
127 days ago
Topic tags/keywords: question angsana milling rustic
From an urban Angsana tree, I chainsaw milled these 3” thick slaps. The plan is to make them into a matching pair of rustic garden bench as I like the natural curve of the slaps. However, a piece (second from left, pic below) developed a long check almost immediately after it’s is milled out. Ends are already sealed with a few coats of paint. This piece of log came from an upper limp, so I guess it is one of those reaction wood that would move and shift after it is milled. Weirdly, the matching piece did not develop any checks at all.
Is there anyway I can prevent the check from developing further as it dries?
OR can the check be forced back together, then lock it with butterfly joint and be dried like that?
-- Make love with wood.
LaPala
#1 posted 126 days ago
One more question…
Should I rough plane the chainsaw milled slap first or wait till they are dry enough?
View bondogaposis's profile
bondogaposis
1246 posts in 520 days
#2 posted 126 days ago
Put a butterfly insert or two in the check. You could rough plane them but there is no real need to until they are dry.
-- Bondo Gaposis
LaPala
#3 posted 126 days ago
Thanks Bondo. Do you think clamping and forcing the check to close before putting in the butterfly is a good idea?
View derosa's profile
derosa
1472 posts in 1005 days
#4 posted 126 days ago
Drill a hole in the end of the check, you’ll have to fill it later but just like a windshield it can stop the crack from spreading, though not every time. Could also try clamping it and as the piece dries make sure you tighten the clamp.
-- --Rev. Russ in NY-- A posse ad esse
bondogaposis
#5 posted 126 days ago
No I wouldn’t try to close it up. You might cause another split somewhere else. Look at how david38 did this project. These things look great when you don’t try to hide them.
-- Bondo Gaposis
LaPala
#6 posted 126 days ago
Thanks guys… here’s the plan from all your advice:
  1. Rough plane the slaps.
  2. Cut a butterfly at the end of the check to prevent the check from developing more (will this work like drilling a hole?)
  3. Clamp and then install a second butterfly further up and let it dry.
  4. Try for a more matching butterfly from the same wood. Prefer the butterfly to be less eye catching.
  5. Making it an Arc-Butterfly (will this work as well for force distribution?)
    Sounds good enough?
