tap and die set
Forum topic by dakremer posted 01-15-2013 05:57 AM 7490 views 0 times favorited 13 replies Add to Favorites Watch
View dakremer's profile
dakremer
2662 posts in 3000 days
01-15-2013 05:57 AM
Anyone ever use a tap and die (the ones made for metal) on wood? I’ve seen the Wood Whisperer use a tap before in wood, which allowed a bolt to be securely held to the wood. You can see him do this here
What about using the die to cut the threads on a dowel??
-- Hey you dang woodchucks, quit chucking my wood!!!!
13 replies so far
dakremer
#1 posted 01-15-2013 06:00 AM
View DKV's profile
DKV
3940 posts in 2413 days
#2 posted 01-15-2013 07:48 AM
View jim C's profile
jim C
1472 posts in 3007 days
#3 posted 01-15-2013 11:11 AM
A normal tap and die set works like a charm. Just don’t try it under 1/4-20 size as the threads are to fine.
You can even drill and tap MDF as long as you drip crazy glue into the tapped hole afterwards. The stuff “hardens the MDF threads.
Stay away from the super cheap sets sold in the big box stores. They just plain don’t work!
I got mine from Amazon. Read the reviews and pick out a set.
View hairy's profile
hairy
2608 posts in 3441 days
#4 posted 01-15-2013 12:54 PM
I do it on accessories I make for my lathe. I tap the wood, then flood it with thin CA glue. When the is glue dry I tap it again to clean out glue residue. End grain doesn’t take threads very well.
-- My reality check bounced...
View SPalm's profile
SPalm
5316 posts in 3791 days
#5 posted 01-15-2013 01:12 PM
Another believer in CA glue here.
When you gotta, you gotta.
Steve
-- -- I'm no rocket surgeon
View poopiekat's profile
poopiekat
4330 posts in 3643 days
#6 posted 01-15-2013 01:24 PM
I wonder if a pipe tap & die might be a better choice than SAE/USS machine screw threads? The threads are coarser. I’m gonna try this!
View johnstoneb's profile
johnstoneb
2794 posts in 2082 days
#7 posted 01-15-2013 01:40 PM
I have had limited success with machine tap and die sets the tighter the grain the better they work. I will try the CA next time . Pipe threads are tapered while they might cut threads OK because of their coarseness they won’t accept anything except another pipe thread. They also are cut as a crush thread to seal.
I have had good luck on wooden geared clocks that need set screws just using the set screw working it in and out until the threads are cut to the depth I need. These are usually 1/8” or smaller. I think the Ca would really work well on them. I am always worried about stripping the threads out.
-- Bruce, Boise, ID
View MrRon's profile
MrRon
4638 posts in 3152 days
#8 posted 01-15-2013 05:52 PM
Since I make train models from wood, I tap holes all the time. One trick I learned to get a tight fitting set screw for a saw insert plate is to use one size smaller tap drill. When you tap the hole, the threads will be slightly oversize and will lock a set screw so vibration won’t loosen it. I use this on #8-32 screws in Baltic Birch plywood, 12/” thick. Works like a charm. As for cutting external threads, a coarse thread on hardwood will work, but I don’t see any application where a V thread on wood would be needed. The threads would be too fragile. There are some taps and dies specially made for wood. They resemble an Acme thread and are much coarser. They are used on some Colonial style American furniture.
TopamaxSurvivor
18199 posts in 3585 days
#9 posted 01-15-2013 09:32 PM
A pipe thread tap should work just fine. The die would too if you run it all the way on to level out the taper.
View Don W's profile
Don W
18608 posts in 2476 days
#10 posted 01-15-2013 09:34 PM
http://lumberjocks.com/donwilwol/blog/24157
View Roger's profile
Roger
20908 posts in 2713 days
#11 posted 01-16-2013 01:21 PM
Some good tips here. Ya learn somethin every day on here.
View helluvawreck's profile
helluvawreck
30177 posts in 2775 days
#12 posted 01-16-2013 01:46 PM
You might want to try spiral point taps. They may be gentler on the wood fibers.
helluvawreck aka Charles
View Wav's profile
Wav
45 posts in 1166 days
#13 posted 09-20-2016 07:08 PM
I’ve seen some talk about NPT Pipe Taps, and they do work well, but the threads are taperd, however, you can find pipe taps that are NPT, they are called NPSF Straight Pipe Taps. they may not be as easy to find and may be a little more expensive, but they do make for a straight threaded hole.
-- Maddog Creations
