Offset Sticks To Transfer Measurement
« back to Coffee Lounge forum
Forum topic by ajosephg posted 1748 days ago 2908 views 0 times favorited 20 replies Add to Favorites Watch
View ajosephg's profile
ajosephg
1726 posts in 1758 days
1748 days ago
Topic tags/keywords: measuring jig question
I’m having an oldtimers moment. Could somebody out there tell me what you call the two sticks that you place side by side and clamp together to be able to transfer very precisely the distance between two points to something else.
-- Joe
20 replies so far
ajosephg
#1 posted 1748 days ago
Dave-
Maybe – but I was thinking it was something more profound.
BTW – I slowly but surely sneaking up on getting back to Sketchup – as soon as I finish writing a story or two.
-- Joe
View tenontim's profile
tenontim
2130 posts in 1941 days
#2 posted 1748 days ago
Actually, Joe, you don’t have to clamp them together. They are best used to make inside measurements. Place them against each of the sides that you’re trying to find the distance between, and make a mark across both sticks. You can move them around, stick ‘em in your pocket, whatever. Then when you’re ready to transfer the measurement, align the marks again, and that’s your distance. Don’t know the official name.
-- Tim-- http://www.tmuli.com
ajosephg
#3 posted 1748 days ago
Dave – No, first story will only have pictures. The subject will be aligning a dog of a TS. Will eventually put it on LJ. Second story is a marketing thing for a client.
Tim – Yes, you are correct. I had forgot about the mark across. Told you, I’m older than dirt. Some people may call them story sticks, but I think they are something else.
-- Joe
tenontim
#4 posted 1748 days ago
I use “story boards” for some of my furniture that I make regularly. But it’s just a piece of wood with various measurements or “points” marked on it. My memory went way south awhile back, and I can’t remember ever hearing a name for the measuring sticks.
View Steelmum's profile
Steelmum
355 posts in 2159 days
#5 posted 1747 days ago
I do believe this is called paired sticks. You can mark or clamp the ‘paired’ sticks to give a precise measurement.
-- Berta in NC
3808 posts in 2218 days
#6 posted 1747 days ago
Are you thinking of story sticks ?
View fredf's profile
fredf
495 posts in 1907 days
#7 posted 1747 days ago
“Frenchmen’s Rule” comes to mind
-- Fred, Springfield, Ma
View Dadoo's profile
Dadoo
1763 posts in 2187 days
#8 posted 1747 days ago
Bob#2 has got it. Cabinet makers use them for getting quick and accurate inside measurements for shelves, doors, etc. I like that pair he linked to but instead of shelling out good money for them, I’ve just used two pieces of scrap.
ajosephg
#9 posted 1747 days ago
OK, I’m going with Story Sticks for inside measurements and the like and Story Boards to use as a reference for furniture “standard” dimensions. I couldn’t find anything about a “Frenchmen’s Rule” but maybe if you put some varnish on them that kicks them up a notch to a Frenchmen Rule.
Appreciate your input.
-- Joe
Dadoo
#10 posted 1746 days ago
Story boards are pieces of your pending project that tell the “story” of how you made that particular cut, joint, route,etc. I use a standard Delta miter saw so when I did the crown molding in my house, I created story boards of the angled inside and outside corners. This type of crown molding requires a compound miter which is possible with my saw if you place the board correctly. Remembering just how to place that board is damn near impossible. So the story boards show you how! And yes, after that project was finished 3 years ago, I still have the story boards!
One of these days though, I’ll buy a nice compound miter saw…with a laser too!
ajosephg
#11 posted 1746 days ago
This is the web site that I was referring to in relationship to furniture, etc. http://www.woodworkingonline.com/2006/06/20/story-stick
There are thousands of hits showing all kinds of uses when you Google “Storyboard Woodworking” I’m thinking that additions to my scrap wood pile would be reduced if I spent some time to use same before starting to cut!!
-- Joe
tenontim
#12 posted 1746 days ago
story sticks, paired sticks, bar gauge, Frenchman’s rule,........ Poultry’s just another name for chicken.
View David's profile
David
1970 posts in 2335 days
#13 posted 1746 days ago
Joe -
I think I know what you are taking about. Check out this link on my blog.
Best Regards,
David
The Folding Rule
ajosephg
#14 posted 1746 days ago
David -
Exactly, but is there a generally accepted name for these?
-- Joe
David
#15 posted 1746 days ago
Hey Joe,
I think they are called “pinch sticks”. I use these all the time and find them quite helpful. I have several sizes on my bench.
David
