Should I sweat warped/twisted drawer bottoms?
Forum topic by Sam_NY posted 01-14-2013 11:16 AM 1592 views 0 times favorited 8 replies Add to Favorites Watch
View Sam_NY's profile
Sam_NY
3 posts in 1833 days
01-14-2013 11:16 AM
Topic tags/keywords: drawers warp plywood
Hi all,
First post here, but lurker for a while…
My question: I cut some drawer bottoms for some large under-bed drawers (approx. 24W x 27D). I wanted something a little heavier, so I bought 3/8” ply and cut grooves in the drawer box. The ply (sanded pine from HD) has warped significantly since I cut them to size. Actually it’s more like a twist.
I’ve been weighting them down flat, but haven’t tried spraying with water, etc. I’m wondering if I should try to resolve before assembly/glue-up, which I guess depends on whether the drawer will force the bottom flat again or whether the warp/twist will instead to pull the drawer box out of square. Any thoughts? The drawer sides 3/4” birch ply and are about 8” tall.
Thanks for any advice.
8 replies so far
4825 posts in 2364 days
#1 posted 01-14-2013 12:36 PM
Those are pretty robust drawers, and I’d bet that 1/4” ply for the bottoms would have been plenty. I think I would assemble them and see…my guess is that the sides are stout enough to straighten out some minor twist. But if that 3/8 ply is doubled over you may want to make new bottoms.
View EEngineer's profile
EEngineer
1089 posts in 3484 days
#2 posted 01-14-2013 02:07 PM
To me, with 24”W X 27”D X 8”H drawers, 1/4” seems marginal. I think 3/8” is more appropriate. However, as underbed drawers, they may never be subjected to as much load as, say, shop or kitchen drawers.
I agree with Fred, though – 3/4” drawer boxes are pretty stout. If you make them like traditional drawers, i.e. dado or dovetail at the drawer front and back dadoed into the sides with the drawer bottom slid into the grooves at the drawer bottom after the box has been assembled, I don’t think the bottoms will cause the drawer to warp.
Plywood doesn’t move much at all with changes in the seasons or humidity. I would consider gluing the drawer bottom in, also – don’t leave it floating like most drawer bottoms.
View RussellAP's profile
RussellAP
3103 posts in 2158 days
#3 posted 01-14-2013 03:21 PM
It’s a pretty stout design using 3/8 ply, but if you have room under the bottom, I’d span the 24” width with a piece of hardwood for support. 2 feet is a lot of room for heavy clothes and it will eventually warp it without some support.
Sam_NY
#4 posted 01-14-2013 03:38 PM
Thanks for the replies. I was up in the air about whether to go 1/4” or 3/8” for the bottoms.
EEngineer, that is how I constructed the drawers: dadoes front and back with grooves cut for the bottom. I was thinking about gluing the bottoms as you suggest to help keep everything rigid.
I just put one together dry and it occurs to me now that once fitted in the grooves, most of whatever pressure from the warp is probably exerted on the groove itself, not the joints, if that makes any sense. Anyway, since it seems okay dry, guessing I’ll be safe once it’s glued up. Just being paranoid…
Thanks again for the advice.
Sam_NY
#5 posted 01-14-2013 03:49 PM
Russell: I did leave a little extra space beneath the groove just in case I decided to do that. Certainly can’t hurt!
View MrRon's profile
MrRon
4561 posts in 3115 days
#6 posted 01-14-2013 08:32 PM
Replace the bottoms with 6mm Baltic Birch plywood in a 1/4” wide dado.
9762 posts in 3519 days
#7 posted 01-14-2013 08:36 PM
Put a drawer together dry to see if the bottom twist is
strong enough to twist the drawer.
Ball bearing slides can prevent a drawer from twisting.
I don’t think an out-of-flat drawer bottom in your situation
is likely to be a deal breaker, but it depends on the
fit tolerances you are working to.
View pintodeluxe's profile
pintodeluxe
5544 posts in 2684 days
#8 posted 01-14-2013 09:03 PM
If the drawer bottoms are to be assembled into a groove in the sides, assembly will likely correct most of your problem. When you groove the drawer parts, you might aim for a slightly loose fit to give yourself some wiggle room during assembly.
