design help with legs on piesafe/pantry
Forum topic by jdh122 posted 128 days ago 278 views 0 times favorited 3 replies Add to Favorites Watch
View jdh122's profile
jdh122
100 posts in 987 days
128 days ago
I’ve been working for quite a while now on this large pantry-ish piece (I’d call it a pie safe, except that the doors are frame-and-panel wood rather than tin with holes). I decided to build the carcase out of four solid pieces, yellow birch for the sides and white pine for the top and bottom that don’t get seen. The pieces are joined by dovetails (see picture of the bottom – the scerws are there to attach the sliders for the drawers and are not structural).
I’m looking for advise on choosing and attaching legs. The lines of the piece are pretty undecorated (as you can see, although there will be crown molding on the top) so I’d kind of like to put simple tapered straight legs in the four corners, about 8 inches high. But I can’t figure out how to attach them. Any ideas?
Thanks,
JH
3 replies so far
View Ross's profile
Ross
84 posts in 142 days
#1 posted 128 days ago
Maybe build a table with 8” legs the same dimension as the pantry and set the pantry on top of it and secure it from pantry floor to table top.
-- "Man Plans and God Laughs"
View bondogaposis's profile
bondogaposis
1245 posts in 520 days
#2 posted 128 days ago
I see 2 options. One, make a base like a table skirt and legs or two, make a plinth.
-- Bondo Gaposis
jdh122
#3 posted 127 days ago
Thanks for the advice. I guess I should have made the legs integral to the design, but I’ll come up with something, possible simple double legs in the corners, mitered with a block behind them – a variation on the plinth, just without the pieces being joined in a whole base.
