panel thickness for shaker doors
Forum topic by Havasumatt posted 126 days ago 464 views 0 times favorited 7 replies Add to Favorites Watch
View Havasumatt's profile
Havasumatt
25 posts in 519 days
126 days ago
Topic tags/keywords: question tip shaker plywood cabinet door rabbet
well, i’m making some upper cabinets for mother in law, and staying cheep using left over plywood for the doors. i was goin shaker style for the doors but using 3/4 luan for rails and stiles. probably 3 in wide. but was wondering if i use 1/2 in ply for the panels. would rabbeting the 3/4 frames for the 1/2 in be too much? if they were for me i would use poplar for the frames and 1/4 ply for the panels, but this is a low budget build. i have 1/4 in ply i could use but its been sittin for years and is a little warped. thats why the 1/2 ply came into play but not sure if that deep of a rabbet is to much. anyone seen cheap doors made like this?
7 replies so far
View HerbC's profile
HerbC
776 posts in 1026 days
#1 posted 126 days ago
Use the 1/2 plywood, but make the slot in the rails and styles 1/4 inch and rabbit the back edge of the plywood to make the remainder 1/4 inch thick to fit in the slot.
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View joeyinsouthaustin's profile
joeyinsouthaustin
513 posts in 239 days
#2 posted 126 days ago
We use a 1/4” channel in the style and rail, and usually 3/8’ for flat panel. We back cut the panel to fit in the 1/4” groove. Or 3/4 thickness for raised panel, still back cut to fit in a 1/4” groove. Use the 1/2” but back cut the panel to fit in a 1/4” groove. Then your cope will be 1/4” shoulders with a 1/4” tongue.
-- Who is John Galt?
joeyinsouthaustin
#3 posted 126 days ago
HerbC jinx…. I get a pop.
Havasumatt
#4 posted 126 days ago
Hey thanks! Since I’m not happy with usin ply for rails and stiles, I wasn’t even gonna tongue and groove the panel into them. Was just gonna rabbet the back and recess the panel into them. Once again, can’t argue with the mother law. “What do you mean I need to get more wood, you have all that leftover sittin around”. Arrggghh!
Havasumatt
#5 posted 126 days ago
Ok, done venting….. Gonna rout the groove it the rails as stiles.
View Loren's profile
4873 posts in 1815 days
#6 posted 126 days ago
I think they look best if the door is recessed 3/8”, so if
you want to do that and use 1/2” ply with 3/4” frames,
the ply will be 1/8” proud on the back. This is not
inconsistent with historical examples that even used
thicker raised panels turned inward. Despite the historical
precedent clients may freak out when they see it.
View Dusty56's profile
Dusty56
10508 posts in 1855 days
#7 posted 126 days ago
”clients may freak out when they see it.” Loren , thanks for the laugh : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
