long centerd holes
« back to Woodturning forum
Forum topic by trz posted 131 days ago 336 views 0 times favorited 3 replies Add to Favorites Watch
View trz's profile
trz
56 posts in 658 days
131 days ago
what’s the best way to bore a centered hole through an 18 in long 3×3 turning blank?
3 replies so far
View crank49's profile
crank49
2291 posts in 1142 days
#1 posted 131 days ago
Gun Drill
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View JNP's profile
JNP
103 posts in 749 days
#2 posted 131 days ago
split it, route a channel in each side and glue it back together?
-- Jeff
View Wildwood's profile
Wildwood
349 posts in 306 days
#3 posted 131 days ago
Lamp auger
http://www.highlandwoodworking.com/lampaugerbit516.aspx
http://www.woodturnerscatalog.com/p/4/-/12/65/-/5330/Turners-Select-3-8%2522-Lamp-Auger
Long drill bits
http://www.amazon.com/Neiko-Tools-USA-Long-Drill/dp/B000VUY5FA
http://www.harborfreight.com/1-2-half-inch-mt2-mini-lathe-drill-chuck-42340.html
Hard to drill out a long blank on a mini lathe without bed extension. Will need a 4-jaw chuck and remove live center from tailstock to use lamp auger. Using long drill bits requires 4-jaw chuck and drill chuck and flipping blank around.
Back out bit, often clearing chips insures a straight hole through blank. A steady rest helps, homemade versions work well.
-- Bill
