stearated sand paper
Forum topic by wiser1934 posted 01-13-2013 03:20 AM 1596 views 0 times favorited 10 replies Add to Favorites Watch
View wiser1934's profile
wiser1934
524 posts in 3110 days
01-13-2013 03:20 AM
Topic tags/keywords: sanding finishing
i have heard that if you use a stearated paper for sanding, you will have trouble if you finish with poly. any body??? thanks
-- wiser1934, new york
10 replies so far
View TheCook's profile
TheCook
39 posts in 2083 days
#1 posted 01-13-2013 03:20 AM
What?
wiser1934
#2 posted 01-13-2013 03:43 AM
by your reply i would assume no problem. i know that if you use anything with a wax base like shellac, poly will not dry
View ajosephg's profile
ajosephg
1880 posts in 3524 days
#3 posted 01-13-2013 04:03 AM
No, you won’t. I’ve used a lot of it and have not had the slightest problem
-- Joe
View Loren's profile
10244 posts in 3611 days
#4 posted 01-13-2013 04:41 AM
I use it with no problems. The fine stearates leave white
stuff in the pores, so it’s important to blow, vacuum and use
tack cloth… or at least that’s what I do. In terms of
an adverse affect on finish adhesion… none that I know of.
View MonteCristo's profile
MonteCristo
2099 posts in 2151 days
#5 posted 01-13-2013 04:42 AM
Sounds like an old wive’s tale at best . . .
View NiteWalker's profile
NiteWalker
2736 posts in 2540 days
#6 posted 01-13-2013 01:27 PM
You’re not supposed to use stearated sandpaper when using water borne finishes. I’ve had no issues with norton’s 3x or 3m’s sandblaster with water bornes though.
4945 posts in 2456 days
#7 posted 01-13-2013 04:54 PM
I think with certain stearated paper and certain finishes you can have a problem. I think this happened to me once with a waterborne finish, Target Coating PSL ( the name has been changed a few times) and Klingspor paper. But I’ve used a lot of stearated paper on other stuff and never saw the same effect. The problem I had was adhesion, and only in certain spots. The finish came off in a very sharp edged spangled looking spot (several spots, actually). OTOH, I may have mis diagnosed the whole thing. But polyurethane resins do inhibit adhesion (that’s why you sand between coats) so I suspect there is a possibly….maybe just a remote one.
wiser1934
#8 posted 01-14-2013 01:58 AM
thank you
View DKV's profile
DKV
3940 posts in 2467 days
#9 posted 01-14-2013 02:05 AM
I learn something new on this site all the time.
Stearate Lubricant
Often made of a metallic soap, the stearate is a dry lubricant applied to the surface of the paper, filling in the space been the grains. The application of the stearate prolongs the life and use of the paper, preventing the sanded material from clogging the areas between grains.
-- This is a Troll Free zone.
wiser1934
#10 posted 01-14-2013 02:07 AM
thank you
