Chip breaker question
« back to Hand Tools forum
Forum topic by Oldelm posted 01-12-2013 11:37 PM 844 views 0 times favorited 2 replies Add to Favorites Watch
View Oldelm's profile
Oldelm
75 posts in 2170 days
01-12-2013 11:37 PM
Topic tags/keywords: planes chip breaker
Based on all the recent articles on the subject I have decide to reshape the chip breaker on my 409 to an 80 deg bevel. I believe this will work ok for a dedicated smoother. I don’t think it would work so well for another # 4 I use for general bench work or on my # 5 ’s or my # 6 that I use as a jointer. I would like to hear some opinions on chip breaker bevels for planes used for work other than smoothing.
-- Jim, Missouri
2 replies so far
View StumpyNubs's profile
StumpyNubs
7590 posts in 2796 days
#1 posted 01-13-2013 01:19 AM
There was a great study on the effects of a chip breaker on a plane at different angles. Here's the link.
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
Oldelm
#2 posted 01-13-2013 05:03 PM
Stumpy thanks for the heads up on the study. I had looked at it. I get the idea, at least I think so, of the steep grinds on the chip breaker. You might tell me if I have it wrong. The 80 deg. grind will get the plane to act somewhat like a card scrapper. If you try to take a larger shaving with it you are going to hit the wall so to speak. What I was looking for is an angle that works well for a bit heavier of a shaving for general use. I was trying to get there the easy way without having to experiment for myself. I would start out at 45 which would mean to me you would be 90 or so from the sole and see if that would turn a little heavier chip without making work like pushing a screwdriver. It looks like the original breakers are about 30 and that is probably ok for a jack plane. I just looking for a little better performance than that. I realize that many things can influence the performance.
-- Jim, Missouri
