| Forum topic by ashahidan | posted 158 days ago | 433 views | 0 times favorited | 4 replies | ![]() |
158 days ago |
Topic tags/keywords: miter saw I saw someone using a cut-off saw like a meter saw. He fixed a circular saw blade to the spindle instead of the abrasive blade . Is it safe to do such thing? -- asm |
#1 posted 157 days ago |
If the arbor is the same size, I can’t imagine a problem with it. On the other hand, if you have to use a bushing or modify the blade in some way, might not be so good. And I’d want to know what the blade encounters after it’s through the wood. I guess you could put a wooden base on there for the blade to contact. |
#2 posted 157 days ago |
The only issue that comes to mind is the RPM of the saw, though it’s likely within a safe range. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#3 posted 157 days ago |
I’ve done that several times and got along fine BUT the fence on those metal chop saws is not real precise.I would use a blade designed for use in a mitersaw. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#4 posted 155 days ago |
Thank you for all the replies. The abrasive blade of my my cut-off saw is 13 inch in diameter and the spindle speed is 1280 rpm. If I were to buy a 12 inch circular blade I will poorer by nearly $100.00. A Bosch 8” circular saw costs about $150.00 and is much safer and l wouldn’t make so much noise. I think I better wait to buy a real circular saw and fix it to a rigid table. -- asm |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15978 |
Hand Tools
2095 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2776 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
