how bout a fence
Forum topic by CudaDude posted 01-12-2013 03:19 AM 1129 views 0 times favorited 9 replies Add to Favorites Watch
View CudaDude's profile
CudaDude
179 posts in 2305 days
01-12-2013 03:19 AM
now that i have my TS going i need to put a fence on it. briefly thought about dropping the cash on a incra but i’m limited on space so i don’t know if it’d be worth it for me.
so… what do ya’ll recommend for a unisaw x5 3hp? i’d eventually like to incorporate my router into the TS extension.
-- Gary
9 replies so far
View DKV's profile
DKV
3940 posts in 2501 days
#1 posted 01-12-2013 05:00 AM
Dragons, everywhere I go there you are…
Are you following me?
-- This is a Troll Free zone.
CudaDude
#2 posted 01-18-2013 10:22 PM
need to get a fence on this thing. all i’m coming up with is vega, biesemeyer, and incra. looks like the biesemeyer and incra with the same rip capacity are close in $$. read up on the incra, so i know all the good points but what about the biesemeyer? read some good reviews on the biesemeyer, but haven’t seen why. what makes it almost $200 better than the vega?
-- Gary
View Brandon's profile
Brandon
4152 posts in 2948 days
#3 posted 01-18-2013 10:24 PM
For a Unisaw, I’d go with a Biesemeyer; it’d feel right at home. For a cheaper alternative, have you looked into the Delta T2 fence?
-- "hold fast to that which is good"
View sixstring's profile
sixstring
296 posts in 2240 days
#4 posted 01-18-2013 10:42 PM
CudaDude, I’d be curious to know the difference myself. I went with a Vega Pro 50 (something like that,) for my Powermatic 66 and I’ve had no regrets over the last year using it. I had been looking at the ShopFox and Biesemeyer fences and the only complaint I’ve heard from others is that the Vega uses a round pipe for it’s rail while the others use square tubing which may be more, uh, not really sure… Also, the little brass piece that locks the fence down to the rail can break easily if you over tighten the lever. Frankly, you barely have to put any pressure on it for the fence to hold up to anything so just know that in advance and dont be a knucklehead with your gear. Havent had any problems with the Vega myself and think I saved $200 or so over the Biesemeyer.
Another great reason for the Vega is how simple it was to install. No drilling. Just bolt the badboy on and adjust the tape if necessary. It was square to my blade almost immediately and has stayed that way. Even after ripping/resawing heavy 4×12s. I’d buy it again for another saw without thinking twice.
There’s my 2 cents.
-- JC Garcia, Concord, CA : "It's easier to ask forgiveness than permission..."
117091 posts in 3574 days
#5 posted 01-18-2013 10:54 PM
I’m have had my PM 66 for 20 years it has a Biesemeyer fence and it has been rock solid for all those years I have used many saws with many fences, perhaps all of the brands that they make (except incra)and have not found a fence I like better.
View Tedstor's profile
Tedstor
1643 posts in 2630 days
#6 posted 01-18-2013 11:23 PM
I have a T2 on my craftsman 113. Its a great fence and I’m thoroughly satisfied. It was a good choice for my saw. And at $160 shipped, it was the most practical fence for my $75 table saw.
But I couldn’t imagine buying a Unisaw and NOT installing a Biesemeyer. Afterall, a unisaw may very well be the last saw you ever buy. I’d install an equally nice fence.
Either the T2 or Bessy should be a direct bolt-on for a unisaw. And while the T2 would probably be “good ‘nuff” for a Unisaw, the Bessy would be it’s equal.
View RockyTopScott's profile
RockyTopScott
1186 posts in 3475 days
#7 posted 01-18-2013 11:34 PM
I have never regretted buying my INCRA for one second.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View JesseTutt's profile
JesseTutt
854 posts in 2108 days
#8 posted 01-18-2013 11:45 PM
My Delta saw came with the UniFence. I was told that it was the best fence. I found out that that was not the case. Do Not consider a UniFence or if you do please buy mine.
I switched to the Incra LS-TS fence and love it. I wish I could change the actual fence that the wood rides against as it is hard to add accessories that slide along the fence. But overall it IMHO has the most accuracy and repeatability anywhere.
CudaDude
#9 posted 01-18-2013 11:54 PM
Jesse, what is it you don’t like about the unifence? That’s what I was originally looking for, but gave up the search. If I were interested, what would you take for it?
-- Gary
