Craftsman table saw 113 series
Forum topic by indychips posted 01-11-2013 09:53 PM 20072 views 0 times favorited 18 replies Add to Favorites Watch
View indychips's profile
indychips
17 posts in 2162 days
01-11-2013 09:53 PM
The other day I posted a Hitachi table saw that I saw craigslist. Thanks for all of your replies, but I did not get it. The seller just would not budge on the $375 asking price.
So now I would like to know more about this saw:
http://indianapolis.craigslist.org/tls/3523010340.html
Asking price is $175. It is a Craftsman model 113.219315. Good saw, bad saw, price? Any help would be appreciated. Thanks again for all of your help in my search for a bigger, better saw than the one I currently have.
18 replies so far
View JayT's profile
JayT
5668 posts in 2233 days
#1 posted 01-11-2013 11:08 PM
Those can be a pretty good saw with some tweaking. They were built in the USA by Emerson for several brands and are solid saws. I have one and really don’t feel the need for anything bigger. It works great for 4/4 stock and the occasional softwood 2x, though it would be underpowered for someone using a lot of 6/4 & 8/4 hardwood.
That looks like an Align a Rip fence in the picture, and I have never used one of them. It is probably better than the base factory fence you see on a lot of this style Craftsman, but I don’t know how it compares to a T2 or similar upgrade. Hopefully someone with experience with the Align a Rip can chime in.
Price isn’t too bad. The 113’s of that vintage with the crappy factory fence pop up around here for 125-150 pretty regularly, with occasional ones in the $75 range. If the fence is a keeper, it would easily be worth the asking price.
View Tedstor's profile
Tedstor
1643 posts in 2654 days
#2 posted 01-12-2013 12:22 AM
Normally, I’d say a later model 113 is worth no more than $125. That is because the stock fence sucks and needs to be immediately upgraded. However, the saw you reference looks to already have an upgraded fence. That said, $175 isn’t bad. Offer $150 and take it home. It should clean up nicely.
I have a “3 hp” 113 with a Delta T2 fence. I have no plans to replace it until I can store/afford a cabinet saw.
View EEngineer's profile
EEngineer
1103 posts in 3635 days
#3 posted 01-12-2013 02:52 AM
I believe (but I haven’t been able to confirm this) that the Align-a-Rip fence was actually made by Ridgid for Sears. I upgraded to the Ridgid AC1036 on my Craftsman saw and it looks absolutely identical to the fence on the saw you referenced.
Very fine fence. I bought mine used 4 or 5 years ago, spent some time installing and tuning it to the saw and it has been stable ever since. See it here. I like this fence design better than the Beisemeyer or other T-square fence designs because it solidly locks the fence at both the front and back of the saw.
These old Sears are pretty darned good. They were made by Emerson. Before they went to granite tops, the best rated contractor’s saw being sold was the Ridgid 3650, 3660. They were made by (drum roll please…) Emerson. On the web you can find pictures of the bottom of the saw table and trunnions for both the old-style Craftsman saws and the newer, highly rated Ridgid 3650 or 3660 saws. Compare – THERE IS NO DIFFERENCE! The biggest difference between old Craftsman saws and the Ridgid 3650, 3660 saws is the fence. Ridgid just spent the time to design a better fence.
With a little TLC, that saw with that fence will serve you well.
View knotscott's profile
knotscott
8055 posts in 3397 days
#4 posted 01-12-2013 02:54 AM
That’d be a keeper at $175 if it runs well. You can always offer less, but I’d pay the $175 if need be. Align it, put a good blade on it, and make dust.
View toolie's profile
toolie
2134 posts in 2650 days
#5 posted 01-12-2013 04:56 AM
another positive experience with 113 saws, here. i have two. a c-man with a t2 fence and a ridgid 2412 with a 1036 fence (36” rip capacity). love them both and sold a unisaw i refurbished in order to keep the 113 style saws.
the linked CL saw is not 3hp, but probably more like 1 hp, maybe 1.5 but certainly no more than that. my c-man w/ a t2 is a 1hp that rip 8/4 hardwoods without incident. it needs a splitter and blade guard which are available from several sources. if you can find a herc-u-lift, it’ll bolt right to that base and it’s thenbest open stand mobile base ever made (currently out of production, but they pop up on CL/ ebay every so often). replacing those stamped wings with CI wings will help dampen vibration and smooth out the saw’s performance.
EEngineer…..sorry to disagree. IMHO, the best contractor saw ever built was the ridgid 3612, which was built by emerson for ridgid. the 3650/60 was, i believe, built under the ridgid brand by one world technologies, which also builds for ryobi and other brands.
View gawthrrw's profile
gawthrrw
207 posts in 2469 days
#6 posted 01-12-2013 05:48 AM
I had one of these saws for about four years until I upgraded. I ended up spending the money and put machined pulleys, link belt, and a T2 fence on it. all said and done I had about $300 in the saw. The only reason i got rid of it was because the threads on the arbor were smaller than the flat area where the blade sets and i couldnt use a dado blade and get a smooth bottom. I called Sears and they acknowledged that some of the 113’s had this issue but there was no replacement at that time. If you dont use a dado blade much than this saw would work great for you. My uncle has the align a rip fence in the picture and he still has to measure the front and back of the fence when he moves it. Spend the money and get the T2 Delta fence. My only regret buying the saw was that it took me two years to upgrade the fence!
P.S. If you can find the cast iron wings for it the saw will have more heft and not vibrate as much…
-- Rob, Dallas TX
knotscott
#7 posted 01-12-2013 01:06 PM
The 3650 was indeed made by TTI/Ryobi for Ridgid, which is owned by Emerson. The 3612 was the last of the US made Emerson contractor saws. Pretty much the same design through out….and all have plenty of parts that are interchangeable. Craftex still offers a version of the 3650 in Canada. AFAIK TTI still makes the R4510 and R4516 portable jobsite saws for Ridgid, and the nearly identical Cman 21828.
For those interested, the former Ridgid R4511 was made by (or in conjunction with) Steel City/Orion….same guts as the current Sears 22116. The current R4511 and 21833 are allegedly made by (or in conjunction with) Dayton….some confusion comes up because Sears uses Colovos as an importer for that model.
EEngineer
#8 posted 01-12-2013 01:15 PM
Well, toolie and knotscott, you might be right. If so, the design was a shameless copy of the Emerson design.
Here’s a picture from an online review of the TS3650:
and here’s a picture from the restore of a 1964 Sears 113 saw from OWWM:
Aside from minor casting differences, the trunnions are the same. Hell, the castings went through bigger changes than this during the 50-60 year history of Emerson making the saw for Sears.
I have heard of arbor/dado blade issues with the 113’s. Further proof of the similarity between the designs is that some reported fixing their arbor issues by ordering and installing arbors for the TS3650 in their 113 model table saws.
View hhhopks's profile
hhhopks
651 posts in 2399 days
#9 posted 01-12-2013 01:36 PM
The only real compliant on my 113 TS is that you can’t lower the blade far down enough to my liking.
When I first got mine, the blade can only lowered such that the 10” blade is jut a hair below the table top.
I had to grind the curve slot (travel limit) for the lower end show that the blade will sit about 3/8” of an inch below the table. I think other 113 TS owner have simular problems. Maybe it is only a problem for certain 113 models.
After making that correction, I am happy with mine TS Oh, I also have the Align-a rip fence. It was a major improvement over my previous saw.
The only other thought is my TS table top height along with a mobile base. I thought the height is a bit to tall for me. I think I would like to have a lower base.
-- I'll be a woodworker when I grow up. HHHOPKS
View History's profile
History
399 posts in 2003 days
#10 posted 01-12-2013 01:40 PM
( Toolie : IMHO, the best contractor saw ever built was the ridgid 3612 ) I’d have to disagree, my vote goes to the Rockwell’s and Delta’s.
knotscott
#11 posted 01-12-2013 01:52 PM
Which is best is subjective. I don’t pay too much attention to the logo generally….I usually just see pros and cons of the pieces parts. I never had any issues with my two saws that used connecting rods as an arbor carriage, but I’ve always thought the one piece cast arbor carriage is a more elegant design. I suspect the Rockwell and earlier Delta’s had stronger motors, and possibly more rugged components, but see the design advantage going to Emerson’s one piece system.
toolie
#12 posted 01-12-2013 03:14 PM
pedantic little nit picker that i am, i believe that should be 4512, no?
indychips…........what did you decide to do about the saw you linked?
toolie
#13 posted 01-12-2013 03:18 PM
i don’t think so. i have both an emerson built c-man and a ridgid. i’ve also disassembled two others for parts. all stored the blade only ~1/8” below the table top. i believe it’s designed that way.
knotscott
#14 posted 01-12-2013 03:27 PM
”The current R4511 and 21833 are allegedly made by (or in conjunction with) Dayton….
pedantic little nit picker that i am, i believe that should be 4512, no?”
That’s no knitpick! Your’e correct. I screwed it up and can no longer edit. R4512 as the intended model number!
indychips
#15 posted 01-12-2013 10:57 PM
Thanks everyone for your responses. I went to look at the saw. Saw was in bad shape, the aluminum rail which holds the fence was cracked. This caused the fence to be loose. The whole table shook like crazy when you turned it on and off. I took a 6/4 piece of walnut with me to run through the saw. The blade came to a complete stop half way through the walnut. Obviously I had to pass on it
Good news is that I stopped to look at a used Ridgid. Perfect shape and bought it for $250. Here is a link to what I ended up buying.
http://indianapolis.craigslist.org/tls/3539152041.html
Thanks again for everyones help.
