Is the Blade Guard really necessary ?
Forum topic by fstellab posted 01-11-2013 04:32 PM 3003 views 0 times favorited 55 replies Add to Favorites Watch
View fstellab's profile
fstellab
86 posts in 2200 days
01-11-2013 04:32 PM
Topic tags/keywords: question tablesaw blade guard safety
Folks,
I know this question could get me banned from woodworking, but I am new so please be forgiving.
The only thing I don’t like on my new Ridgid R4512 is the blade guard. The main issue is that I can’t see the the blade with it on. It seems to me that if I could see the cut, I might be able to see problems, like smoke or issues with the wood pinching together. Also, the guard is a bit flimsy and wobbles. This is not unique to the Ridgid, I looked at a bunch of table saws in the $500 range, they all had the same problem.
I purchased a Grr-Ripper model 200, it give very good protection when doing rip cuts. I have several good push sticks and push blocks.
The knife and anti kickback are in place .. and will stay there, but I am tempted to take off the blade guard and leave it off.
I thought I would check in with you folks first.
Thanks
-Fred
-- Fred Stellabotte (kamado@comcast.net)
55 replies so far
View Manitario's profile
Manitario
2631 posts in 2998 days
#1 posted 01-11-2013 04:40 PM
I have had a couple of TS with similar “issues” with the blade guard; I too ended up removing it and using a riving knife. My current TS has a very good guard that allows me to see the work well and isn’t flimsy; I use it as much as I can; it’s just one more level of protection from absentmindedly contacting the blade.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3273 days
#2 posted 01-11-2013 04:46 PM
Fred…I have a Sharkguard for my Unisaw…I hate it. I feel it doesn’t do any good unless it’s snug over the blade and if I do that, all the thin waste cuts get caught under the guard. I just haven’t gotten comfortable using it and feel that if I can’t properly see the blade that it’ll be a bad thing. I try to keep the splitter on, however. I think that’s the more important part.
-- jay, www.allaboutastro.com
View Wiltjason's profile
Wiltjason
56 posts in 2077 days
#3 posted 01-11-2013 04:49 PM
As much as I hate to admit it I haven’t seen My blade guard in years. Knock on wood I haven’t had an accident with my table saw in which the blade guard would have saved me though.
View Monte Pittman's profile
Monte Pittman
29784 posts in 2453 days
#4 posted 01-11-2013 04:56 PM
No blade guard on mine either
16276 posts in 4333 days
#5 posted 01-11-2013 05:05 PM
I have to admit, my blade guard rarely sees any use. However, I do have a splitter installed.
I want to be clear for any inexperienced table saw users out there: If you have the type of saw where the blade guard also functions as the splitter, you should NOT remove it unless you install a splitter that attaches to a zero-clearance insert, or a similar safety device to avoid have the wood pinch the blade.
View Swyftfeet's profile
Swyftfeet
170 posts in 2286 days
#6 posted 01-11-2013 05:09 PM
I think what you would find that the majority of regulars on this site would be proponents of safety measures due to the sheer number of beginners that visit.
I would bet that less than 1/3 use them on older saws in private residence. My old grizzly 690 that I got off of CL was used primarily as a Dado saw in a shop and the guy had lost it. So I got the adjustable micro jig and just respect the saw.
I wont lie, I think very hard every time before I hit the power button. where I am standing, floor clear, ensure that my tables are clear, ect.
I’ve had two kick backs, one where I got a decent bruise in my hip… I now stand in a different spot and never push wider than long stock thru without using the Miter.
-- Brian
View LeChuck's profile
LeChuck
424 posts in 3177 days
#7 posted 01-11-2013 05:09 PM
Ridgid R4512 for me and I never use it without the blade guard (at least when not using a sled), which I like, except for those metal parts that force me to keep my miter gauge further away. Don’t see a valid reason to remove the blade guard and do away with that added safety.
-- David - Tucson, AZ
View Don W's profile (online now)
Don W
18931 posts in 2682 days
#8 posted 01-11-2013 05:12 PM
same here. I wish I could use it, but just can’t.
View pintodeluxe's profile
pintodeluxe
5738 posts in 2928 days
#9 posted 01-11-2013 05:13 PM
Ever notice on woordorking shows they saw “The blade gaurd has been removed for clarity” yeah, right.
The two biggest things you can do for TS safety (short of buying a sawstop), are…
1. Only run straight, freshly jointed stock on your TS.
2. Make use of featherboards and push sticks whenever you can.
View knotscott's profile
knotscott
8120 posts in 3490 days
#10 posted 01-11-2013 05:18 PM
IMO the splitter/riving knife is more important than the guard because it helps prevent kickback. I’m sure it’s better to use both, but many stock blade guards are so cumbersome and obscure the view that I tended to not use them. A year or so ago I added the BORK Blade Guard to my BORK riving knife and actually like it because I can see… so I use it!
View Milo's profile
Milo
869 posts in 3434 days
#11 posted 01-11-2013 05:29 PM
This is what I had in my old shop, I blogged about it a couple years ago…
http://lumberjocks.com/Milo/blog/14636
WHile you might think the hanging dust collector is in the way, I got used to it really quickly, and it afforded me some degree of protection from the saw blade.
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
Don W
#12 posted 01-11-2013 05:57 PM
Milo, I’ve often thought about building the overhead dust extraction blade guard. Still thinking…....but its a good idea.
View AJLastra's profile
AJLastra
87 posts in 2343 days
#13 posted 01-11-2013 06:04 PM
I am an absolute safety nut about every machine in my shop. HOWEVER, i must admit that I haven’t used my blade guard in many years. With the exception of a Brett Guard, any other guard just made it more potentially harmful than helpful because I want to see that saw blade at all times. I use antikick back wheels and a Micro jig splitter. I push my stock through with a GRRIPPER push block system. and the most imprtant thing I do just like breathing is unplug the saw after each and every cut when I turn off the saw. i’ve had one kick back incident and that was years ago and it scared the hell out of me and thats what made me get the antikick back wheels. I know. The blade is still exposed even with these other things. If you’re going to work without the guard, you’d better make a habit of prepping yourself for each and every cut you make, being fully aware of what you are going to do, how and for how long. I think if you decide on this mindset going in, working without a guard is safe. You have to keep track of how tuned the saw is and that may mean, for your own peace of mind, checking the squareness of everything once each month. you can never be too careful when it comes to safety with these machines. Just my two cents worth.
Smitty_Cabinetshop
15506 posts in 2733 days
#14 posted 01-11-2013 06:24 PM
I’m one of the 2/3 that Brian ^ identified: User of an older saw that doesn’t have a blade guard. Is it ideal? I guess not. It is what I’m used to, though. Is it inherently safe? I think we all know the answer to that is no. Can it be used safely? You bet. As much as anything, I suppose.
fstellab
#15 posted 01-11-2013 06:29 PM
Thanks folks,
As a newbie, not on a schedule, I take a good amount of time prepping for each cut. I recently ordered 30 BF of very expensive hardwood (Macacauba) for a closet organizer project, so I will definitely setup each cut into that wood. I found some Poplar on ebay that I am using to practice cuts when I started noticing what a pain the guard is. Crosscuts don’t seem to be a problem, but the 1/2” rip cuts I really want to see the blade.
Mio, I really like that Guard-dustcollector—That will become my next project if not sooner.
showing 1 through 15 of 55 replies
