| Forum topic by AZ4ME | posted 126 days ago | 464 views | 0 times favorited | 9 replies | ![]() |
126 days ago |
Topic tags/keywords: question tip finishing refurbishing rustic Hey guys, I’m a new member but have been reading along and admiring your projects for quite some time. |
9 replies so far
#1 posted 126 days ago |
Protect in what way? From water? Wear? Sun? -- Rich;) -"Dada make a big mess?" "Yes Dada made a big mess." |
#2 posted 126 days ago |
The wheel parts will be used for an indoor project, together with another wood, probably oak, maybe maple. The wheels were outside in the Dakotas for many years so you can imagine what type of weather they were subjected to there. They have been in Arizona, also outside for the last 10 years or so, mostly some rain and extreme heat and sun. |
#3 posted 126 days ago |
I use a bunch of old barnwood for indoor projects. All I do is make sure the wood is dry, and does not have any rot, and is insect free by running it though a kiln. I have played with adding topcoats and it always darkens and makes it look fake. You loose a lot of the patina. |
#4 posted 126 days ago |
Do you want a finish that is consistent with the finish on the other parts? If some of the wood is soft or in danger of breaking off, I would consider a thin epoxy, like the WEST system, to stabilize it. Try it on a piece of old barn wood first to see if the finish suits you. -- Good judgement comes from experience. Experience comes from bad judgement. |
#5 posted 126 days ago |
If truly weathered wood, not so sure I’d touch it at all…wagon wheel has to be >50 years old and if still not dust, can’t be any bugs in it. if you want to seal it, I guess plain old sanding sealer would work (probably the same as a watered satin finish poly)...seal the pores without changing the texture/patina. I did use a product years ago for “antiquing” new wood to make it look old (I was making little barns for little collector tractors). The technique has become so popular now that the brand doesn’t matter. Google “antiquing” and get ready to read a lot. |
#6 posted 126 days ago |
I use water based poly on most things. Doesn’t yellow, dries clear. -- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability |
#7 posted 126 days ago |
Thanks for the replies guys, I have plenty of pieces that I will not be using in my project, I will try a couple of the water based poly products on them so I can see the effect it has. Doesn’t necessarily need to be finished I guess since it will be indoors but didn’t know for sure. |
#8 posted 125 days ago |
The thought that came to my mind was not so much about the finishing, but about the moisture content of the wagon wheel wood. If it is significantly different to the other wood that you are using, could you be asking for expansion problems somewhere along the way? I ask the question because I do not know the answer, but I’m sure there are many others who could give an opinion. -- I may have lost my marbles, but I still have my love of woodworking |
#9 posted 120 days ago |
I will check moisture content of all wood before building, hopefully it won’t be a problem since the two woods won’t be fastened together in a traditional way but more like a saddle or cradle type situation with pins. I hadn’t thought of that though so thanks for the input. |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15746 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
