Few questions about zero clearance table saw insert
Forum topic by fstellab posted 160 days ago 740 views 1 time favorited 17 replies Add to Favorites Watch
View fstellab's profile
fstellab
81 posts in 283 days
160 days ago
Topic tags/keywords: zero clearance insert r4512 table saw r4512 crosscut blade ripping blade kerf hook angle lexan tablesaw question
Hi Folks,
I need to install a Zero Clearance Insert for my new R4512 table saw.
Are the store bought ones any good ? It’s very tempting to just buy one.
Do you need a separate insert for each type of blade? I have 3 blades, the general purpose blade that came with the saw, a 90 tooth Ridgid crosscut blade and a Diablo 24 tooth ripping blade. They all have different kerfs and hook angles.
How often do they need to be replaced ?
If I make my own blade, can I use a plastic like Lexan ?
Thanks all
-Fred
-- Fred Stellabotte (kamado@comcast.net)
17 replies so far
View cutworm's profile
cutworm
698 posts in 991 days
#1 posted 160 days ago
Hey Fred. I have the TS3660 and made my inserts from 1/2” MDF. I removed the metal insert and used it to trace with on the MDF. After tracing I cut them close with a jigsaw. From there you can sand or use a router and flush trim bit along with the metal insert to finish. I added a finger hole in mine for removal and a screw and washer on the outfeed end bottom side to help hold it in place. I don’t change inserts with blades but have a few for dados of different sizes that I reuse. I made about 10 while I was into it. I happened upon a piece of MDF in Home Depot that they were selling as scrap and used it. I’m thinking those 10 will outlast me.
I;ve been using this insert for about a year with 2 blades.
There is a lot of info out there on making them. Let me know if I can help.
-- "Actions speak louder than words but not nearly as often." - Mark Twain
View willoworks's profile
willoworks
40 posts in 749 days
#2 posted 160 days ago
I bought the Leecraft insert and couldn’t be happier. It fit like a glove but I always use my Freud blade in it. I do need to pop it out and maybe sand out the slot a bit since I get a bit of blade rubbing. I swap it out even if I only tilt the blade a couple of degrees. I want to keep it tight. I had thought about trying to fabricate one but my shop time is limited and I didn’t want to waste it making inserts!
View sixstring's profile
sixstring
249 posts in 441 days
#3 posted 160 days ago
One for each blade, and one for each angle (ie. 90, 45, etc…) I’d say make your own if you can. I think some folks have gotten away with using plastic cutting boards for material. I used some 1/2” maple for mine and will need to make more at 45deg. When I make angled cuts right now, I just use the original plate… Not ideal for me but it gets the job done and I just have to be extra careful making those cuts.
I dont expect I’ll ever have to replace mine. There’s really no wear and tear on them.
-- JC Garcia, Concord, CA : "It's easier to ask forgiveness than permission..."
View Brandon's profile
Brandon
3967 posts in 1149 days
#4 posted 160 days ago
I’m with cutworm. I built mine using 1/2” baltic birch with a laminate top, but followed the same basic steps as cutworm described. Build many at a time and you’ll have more than you need.
-- "hold fast to that which is good"
fstellab
#5 posted 160 days ago
Hi Folks,
My garage shop in FL gets humid at times, in fact I got a 12”x12” sheet of 1/2” plywood, I cut a few lengths for the boards, came back to it the next day and they were warped, slightly but noticeable.
That is when I thought of Lexan, Ridgid, clear .. and it would interesting to look at (especially with a shop light in the right place.
View crank49's profile (online now)
crank49
2380 posts in 1168 days
#6 posted 160 days ago
I’m hearing folks talk about making inserts for the TS 3660 and others mention using 1/2” material to make the insert. I don’t think so. If you are just responding because you made your own insert, well okay, but the OP is asking about the Ridgid 4512 and it, and the Craftsman 21833 twin are a whole different thing. These saws only have a .11” ledge for the insert to drop into.
On casual observation some folks might think you could just rout out the edge to sit on the ledge. But the ledge is only .125” wide also. I don’t think any MDF, Birch, Maple, or Lexan material lip on an insert .11” thick and .125” wide is going to be strong enough to last very long in this application. Probably a good indication of why the factory inserts are made of steel and held in with magnets.
I made my own insert for my Cman 21833 from a sheet of .10” aluminum. It is held in with a 1/4 turn spring loaded clip.
PS: this POS saw can’t use the insert very well because the lifting / tilting mechanics are so crappy the blade never stays in the same plane and alignment after the height is changed, so I just pitched the insert in the trash after wasting 3 hours building it.
I wish you good luck with your efforts, but I’d just buy one; it’s cheaper than the time required to make one.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View derosa's profile
derosa
1466 posts in 1033 days
#7 posted 160 days ago
I spent a long time avoiding making an insert for mine Hitachi which is designed like the Ridgid however I finally got around to doing it and it was worth the surprisingly little effort needed. My insert is something like 3/32” thick, can’t remember exactly but less then an 1/8” and I made it out of oak. The factory insert used 4 screws to keep the insert level so when I made mine I drilled the matching holes but used the screws to keep it down since the wood seemed so thin and flimsy. I used the factory dado insert as a template and went carefully around with the flush trim bit after sawing close to the line on the bandsaw. Hardest part was countersinking the holes without drilling through, once done though it works great. I made mine in the middle of a project and only had time to make 2, I need to quickly make a few more for angles and other dado combinations.
-- --Rev. Russ in NY-- A posse ad esse
View nwbusa's profile
nwbusa
883 posts in 484 days
#8 posted 160 days ago
I’ve made ZCIs for my R4512. I used 1/8” hardboard (masonite). Here’s a pic for your viewing pleasure :)
-- John, BC, Canada
View oldnovice's profile
oldnovice
1873 posts in 1565 days
#9 posted 159 days ago
nwbusa you did exactly what I do!
I double side tape the factory insert to the melamine coated 1/8” Masonite/hardboard (I have also used baltic birch plywood but I need to relieve the back to clear some casting parts) and cut the perimiter with a pattern bit in my router table. Before I remove the factory insert I drill the two holes with a self centering bit. Mount it in my TS with the blade completely down, turn on the TS and slowly raise the blade.
After the insert gets worn too much I save it for my next Dado cuts!
I don’t really know how many of these I have made for my 45+ year old Craftsman 10” TS.
nwbusa
#10 posted 159 days ago
oldnovice, yep that is exactly how I make mine.
And to be honest, I don’t make a ZCI for every blade I use. For example, I have three thin-kerf blades that see heavy rotation and they are close enough (for me) in kerf to use the same ZCI. The main benefit of a ZCI (again, for me) is to keep thin offcuts from falling into the throat plate. With sharp blades, I don’t have any issues with tearout on most woods.
Edit—you can buy a 1/8th sheet (2’ x 2’) of 1/8” hardboard from HD for a few bucks, and it supplies enough material to make a good half dozen ZCIs.
-- John, BC, Canada
View Richard's profile
Richard
358 posts in 889 days
#11 posted 159 days ago
Woodcraft sells ZCI's. I have one for my TS and it was an exact fit. No complaints.
-- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain
View LeChuck's profile
LeChuck
344 posts in 1260 days
#12 posted 159 days ago
Hmmm, personally, I’ve been using my 4512 for a few months with a thin kerf 50 tooth Diablo blade and have yet to feel the need for a ZCI. Very little tear out, if any, including on plywood, and I feel the dust collection from below the table is better this way…
-- David - Tucson, AZ
oldnovice
#13 posted 159 days ago
I would buy them if I could but my TS is too old and the opening is larger than most off the shelf plates available!
But, on the other hand, if you include shipping making them myself it actually cheaper than buying them!
View jeff's profile
jeff
442 posts in 1662 days
#14 posted 159 days ago
i have the rigid 4512.i purchased zci’s from Leecraft one for my thin kerf blade and one for my dado blade.they both work very well,fit perfectly and appear to be well made.also more dust stays below the zci’s.cuts are much cleaner…
-- Jeff,Tucson,Az.
View me5269's profile
me5269
39 posts in 365 days
#15 posted 159 days ago
+1 on Jeff’s comments. I’ve had no problems with them in 6 months. If you buy both, Woodcraft will give you $2 off each. If you order online, you may have to call them to get the $2 off as the shopping cart doesn’t show it.
Shipping to MA was about $10.
Mike
-- Mike
