| Forum topic by 12strings | posted 131 days ago | 437 views | 0 times favorited | 11 replies | ![]() |
131 days ago |
What is the reasoning and necessity of soaking waterstones? I just got my very first waterstone (a dual-sided 1000/6000) and the instructions say to soak for 5 minutes, or just store it in water. (It is from Japan…I don’t know if that makes it a “Japenese Waterstone” or not.) I was always under the assumption that you could just spray some water on it and use it right away. What’s the problem with this? -- I'm strictly hand-tool only...unless the power tool is faster and easier! |
11 replies so far
#1 posted 131 days ago |
Dunk it in water and you will see why soaking is necessary. |
#2 posted 131 days ago |
These stones are like sponges in that they soak up a lot of water. You need to pre-soak them, especially the coarse ones, so that you can get water to remain on the surface and foam a slurry while you sharpen. The really fine stones (say 4000x or higher) don’t really need pre-soaking . . . -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#3 posted 131 days ago |
I find my 4000 still benefits from a soaking. When I am working with chisels and planes a lot, I just leave my stones in a tupperware container of water so I don’t have to keep soaking them. |
#4 posted 131 days ago |
I only use a waterstone for final hone/polish, so I typically spray my waterstone (king) with a spray bottle so that the top is fully covered (sometimes spreading the water around as needed). Then I will do my other sharpening/back flattening on the more coarse stones (I use DMT’s) and keep an eye out for any dry spots on the waterstone, and re-spray as needed. By the time I get to the waterstone it’s generally ready to go with out having to submerge the whole thing. I only use the top, after all… -- Mos - Twin Cities, MN -- Stanley #45 Evangelist - www.youtube.com/MosquitoMods |
#5 posted 131 days ago |
I use a similar technique to Mos. I tried soaking my King 6000 grit for a few minutes, but found that was really not providing any benefit. I just use a spray bottle and re-apply as I go. -- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain |
#6 posted 131 days ago |
I spray my 8k. Soaking has no effect at all. If I try to spray my 250, 1k or 4k without soaking it first it is dry almost instantly. |
#7 posted 131 days ago |
I guess that’s somewhere I don’t have experience, a 6k stone is all I use, everything else is DMT’s, which definitely don’t benefit from a soaking lol -- Mos - Twin Cities, MN -- Stanley #45 Evangelist - www.youtube.com/MosquitoMods |
#8 posted 131 days ago |
If you soak them thoroughly, they stay wetter during the Sometimes instead of soaking them I use a wet sponge and |
#9 posted 131 days ago |
Thanks for the info…I suppose if I want to use the 1,000 grit without waiting, I’ll have to just store it in water. (I’m impatient). -- I'm strictly hand-tool only...unless the power tool is faster and easier! |
#10 posted 129 days ago |
lower grits….yes, vause they are so porous -- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright |
#11 posted 129 days ago |
I use an old tupperware butter dish (upside down) about 1/4 full with water to store my water stone. I keep the cover on (base) when not in use to retain the bath of water. -- "Man Plans and God Laughs" |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3549 |
15782 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
