Gluing Hairline Crack in Walnut
Forum topic by ChesapeakeBob posted 01-10-2013 02:38 PM 6755 views 0 times favorited 11 replies Add to Favorites Watch
View ChesapeakeBob's profile
ChesapeakeBob
366 posts in 3390 days
01-10-2013 02:38 PM
I made a clipboard as a gift to my son for Christmas. The thickness of the clipboard is 3/8”. There a VERY small crack at one end of the board in the walnut, extending about 2” to 3”. The crack is so small it is barely noticeable. My son described it to me over the phone and I was hoping I could glue it, but I cannot even get a small opening to inject any glue. I thought of a small wood wedge, but the wedge would probably leave more or a mark than the existing crack. I also thought about running it in the tablesaw just far enough (for kerf about 3” long) to remove the crack, and then making a replacement sliver of walnut to glue into place. Does anyone else have any suggestions? Thanks.
-- Chesapeake Bob, Southern Maryland
11 replies so far
View bondogaposis's profile
bondogaposis
4611 posts in 2258 days
#1 posted 01-10-2013 02:44 PM
Leave it alone. If it at some point gets longer or wider then glue and clamp it.
-- Bondo Gaposis
View ajosephg's profile
ajosephg
1880 posts in 3468 days
#2 posted 01-10-2013 02:58 PM
I’ve never tried it, but I’ve heard you can lay a bead of glue on top of the crack, then pull a vacuum on the opposite using your shop vac. That will draw some of the glue into the crack, after which you remove the excess glue and clamp the board.
-- Joe
View Wdwerker's profile
Wdwerker
333 posts in 2141 days
#3 posted 01-10-2013 03:06 PM
+1 on try the vac to pull the glue in. I haven’t tried it either but it should work. If the gap Isn’t open enough for the vac to pull the glue thru then just fill the crack with filler.
-- Fine Custom Woodwork since 1978
View TrBlu's profile
TrBlu
386 posts in 2533 days
#4 posted 01-10-2013 03:42 PM
Put a piece of painters tape on the under side of the crack, then run a bead of thin CA glue along the crack. Allow the CA to flow into the crack. Run a second bead to insure full coverage. The clamp to pull crack together.
Let it sit over night, the remove tape. Sand and refinish glued area if needed.
-- The more I work with wood the more I recognize only God can make something as beautiful as a tree. I hope my humble attempts at this craft do justice by His masterpiece. -- Tim
View Planeman40's profile
Planeman40
1104 posts in 2668 days
#5 posted 01-10-2013 04:00 PM
This is very simple.
Go buy you a bottle of very thin (water-like) cyanoacrylic (CA) glue. Note that this type of glue comes in various viscosities from very thick to very thin. Apply the glue to the crack. it will wick into the crack going all the way inside. Apply some, then wait. Apply some more until the crack is full. If you can pull the crack closed with a clamp, do so, but quickly as thin CA glue can set quickly. Wipe away the excess. Leave the glue to set for at least an hour to make sure it has hardened before releasing the clamp.
A little sanding and you are done!
Planeman
View Lee Barker's profile
Lee Barker
2170 posts in 2758 days
#6 posted 01-10-2013 04:07 PM
I wouldn’t try to close it. You’re just transferring stress to elsewhere in the piece. I would treat it as a surface defect.
I’d get some of the dark colored PVA and rub some into the crack and then sand the area with 180, ROS. The fines will get in the crack and the heat will speed the glue drying. After all is cured, resand and refinish the piece.
The crack will be absolutely invisible.
Kindly,
View _Steve's profile
_Steve
85 posts in 2934 days
#7 posted 01-10-2013 05:29 PM
I have tried the concept of useing a shop vac to suck the glue into the crack. It works great, it leaves glue on both surfaces and when clamped, some will squirt back out.
-- McMaker Woodworks, Where you can give directive for a pending antique.
View dbray45's profile
dbray45
3310 posts in 2684 days
#8 posted 01-10-2013 05:54 PM
One of the issues with walnut – it has stress in it. Put a maple key across the crack instead of trying to hide it. This will stop it from splitting, relieve the stress and look good.
-- David in Damascus, MD
View Terry Ferguson's profile
Terry Ferguson
203 posts in 2575 days
#9 posted 01-11-2013 02:36 AM
I use the CA glue method suggested by Trblu and Planeman40 and I also use Lee’s method. My approach would be to use the CA glue first. If you’re not happy with that, then use the PVA and sandpaper. Sometimes I will do both in that order.
-- Terry Ferguson, Bend Oregon
View Popsnsons's profile
Popsnsons
381 posts in 2889 days
#10 posted 01-12-2013 02:48 AM
I would mask off both sides of the crack. Make some walnut sawdust (table saw) mix the sawdust with wood glue and sand it over the cracked surface. Remove the masking tape.
-- Pops ~ In So Cal...
View Tim Dahn's profile
Tim Dahn
1566 posts in 3472 days
#11 posted 01-18-2013 11:41 AM
Bob,
I would also suck the glue in with a shop vac. You could try it out on a scrap piece first.
