How do I enlarge an existing hole
« back to Coffee Lounge forum
Forum topic by EAGLE posted 450 days ago 1342 views 0 times favorited 21 replies Add to Favorites Watch
View EAGLE's profile
EAGLE
61 posts in 609 days
450 days ago
Does anyone out there know of a jig or tool than can make say…. a 1” hole and make it a 1-5/8” hole or a 1-3/4” hole and make it a 2-1/8” hole if so please let me know. Thanx, your fellow LJ Patrick
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
435 posts in 495 days
450 days ago
You could clamp the piece of wood to the drill press and use a hole saw. However, those sizes might not be available.
You could cut a hole 1/8” larger, get a router with the guide bushing and route the new hole…
-- Rich, WNY, www.nyrockingchairs.com
View Scott Bryan's profile (online now)
20746 posts in 719 days
450 days ago
One method that I have used with door lock sets, with your example above, is to drill a 1 5/8th hole in a piece of 1x scrap, center it over the 1” hole and clamp it in place. This will keep the hole saw on track and let you enlarge the existing hole. You might also want to put a backer behind the piece being drilled to prevent blowout.
View DaveR's profile
DaveR
1527 posts in 618 days
450 days ago
How about using an “Oops Bit”? I bought one from Lee Valley.
It’s thing that replaces the drill bit in a hole saw and accepts a smaller holesaw. You install a hole saw sized to fit the existing hole on the Oops Bit and put it in the arbor of the holesaw which has a saw for the desired diameter on it.
Another way to do it would be to use a wooden ball sized slightly larger than the existing hole. Drill a hole through its center for the drill bit of the hole saw.
-- Until you spread your wings, you'll have no idea how far you can walk.
View Steve2's profile
Steve2
48 posts in 468 days
450 days ago
Center hole on drill press if possible. #2 as the other note, make a jig and center it, and yes those sizes should be readily avialable – they are here.
-- Regards, Steve2
View lew's profile
lew
4500 posts in 653 days
450 days ago
I had a bunch of interior doors that my wife want to replace the knob/latch. Bought new ones before taking off the old ones. Discovered that door hardware from 50 years ago used a smaller hole. This was before the Opp Bit. Used a hole saw to make plugs the diameter of the original hole. Glued them in place. When dried, re-drilled with a larger sized hole saw. The bit for the second drilling followed the hole made by the hole saw drill bit when cutting the plug and everything lined up.
Dick, & Barb Cain
7043 posts in 1197 days
450 days ago
I’d plug it with a 1” dowel, & re-drill it.
View John Gray's profile
John Gray
1754 posts in 783 days
450 days ago
Take the piece with your hole in it to the drill press. Use the bit/saw you used to drill the original. Put bit in chuck center the piece around the drill bit and securely clamp it in that position then replace the smaller bit/saw with the new size bit/saw you want the hole to be in drill away. The new hole will be centered on the original hole.
View FJPetruso's profile
FJPetruso
163 posts in 607 days
450 days ago
I was thinking of the Oops! bit like DaveR.. But instead of buying the bit you could chuck a piece of 1” dowel in a lathe & drill a pilot hole with the lathe that would be centered & glue the dowel with the small centered hole in the original hole Then use the size hole saw that you desire or one of those adjustable circle/hole cutting bits.
-- Frank, Florissant, Missouri "The New Show-Me Woodshop"
View Brent Powers's profile
Brent Powers
14 posts in 484 days
450 days ago
Maybe I’m missing something, but why couldn’t you….
1.) clamp a piece of hardboard to the back of the 1” hole.
2.) use the 1” hole saw to make the center hole in the hardboard
3.) use the hole in the hardboard to locate the 1-5/8” hole saw
14932 posts in 748 days
449 days ago
I’m with Dick, that is how I would do it.
View sIKE's profile
sIKE
1094 posts in 651 days
449 days ago
How about a 1 5/8 forstner bit on a drill press. Center it up and press down…
25806 posts in 1298 days
449 days ago
I’d drill the correct hole size in another board and then clamp it over top of the existing, incorrect one and drill away using the new board to keep your bit in alignment.
I’ve done that when I need a step hole in a board and use multiple forstner bits to cut them. You drill the deeper hole first and then use a guide block to align up the other drills and to drill them on top of the first hold.
This example was drilling a hole for a “T” nut and for a plug hole for the T-nut to be hidden. One for the plug, one for the t-nut and 1 for the bolt to go into the t-nut.
FJPetruso
448 days ago
Looks like we all offer a lot of good ideas but it kinda depends on how accessable the hole is, what kind of tools Patrick has available to use & how accurate he must be in locating the hole. Good Luck Patrick
View dapix's profile
dapix
1 post in 609 days
448 days ago
Hole saws are available in that size, I would use my drill press with a template and lock all on the press bed.
View Paul M Cohen's profile
Paul M Cohen
14 posts in 675 days
448 days ago
Try a router with a rabbit bit, rest the bearing on the existing hole and the bit will make part of the hole the correct size. Then follow up with a template bit using the now correct hole on top to make the rest of the hole the same diameter.
-- Paul, Beaverton OR, www.TravelbyPaul.com
View motthunter's profile
motthunter
2079 posts in 696 days
448 days ago
A drill press is the best solution if you have one and the proper bit. If not,the router technique described above would be my second option.
-- making sawdust....
EAGLE
446 days ago
Thank you all for your help
I now have more than one way to skin that proverbial cat. Your fellow LJ Patrick
View CraftsmanCollective's profile
CraftsmanCollective
45 posts in 459 days
436 days ago
Unless Im running low on sandpaper, I’d use a shotgun in this case. A little rolugh around the edges though..
seriously, all my tricks have already been mentioned. I dont even know why Im posting.. It think I may be sleep-blogging.
-- Robby Myer, Walnut Creek, CA
EAGLE
433 days ago
i must say thank you all for all of your help. I am proud to be a LJ and to see a community (be it cyber) come to the aid of a fellow brother such as myself. I am proud to say that the router did the trick.(Thank you PAUL) It worked like a charm.
View ChicoWoodnut's profile
ChicoWoodnut
895 posts in 713 days
433 days ago
Dang! I was gonna say Light Saber
View GaryK's profile
GaryK
9537 posts in 886 days
433 days ago
Dick has it right. Put any kind of plug in it and re-drill it.
