Shelf + Wood Movement
Forum topic by Fettler posted 01-10-2013 02:26 AM 1040 views 0 times favorited 6 replies Add to Favorites Watch
View Fettler's profile
Fettler
200 posts in 1993 days
01-10-2013 02:26 AM
Topic tags/keywords: wood movement joint moisture
I’m working on a coat rack and trying to figure out the best way to attach a shelf (see pictures of rough layout).
I have a feeling that if I just use glue + pin nails eventually it will crack due to expansion / movement. Then again after I get done coating on the polyurethane It might just be fine?
The shelf is roughly 1/2” x 36” x 4”. Wood is fir and i’m in the Pacific Northwest.
-- --Rob, Seattle, WA
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3155 days
#1 posted 01-10-2013 02:44 AM
Finish will not keep it from moving, but it’s only a 4” board. I’d think it’s safe attaching it however you want.
-- jay, www.allaboutastro.com
View AandCstyle's profile
AandCstyle
3052 posts in 2253 days
#2 posted 01-10-2013 03:15 AM
Pins will bend with the wood movement of approximately 1/8”. As another option, you could make a sliding dovetail or a stopped dado for the corbel and glue it just a little at the back end. HTH
-- Art
View bondogaposis's profile
bondogaposis
4725 posts in 2347 days
#3 posted 01-10-2013 03:22 AM
It is really a non – issue w/ this design because the corbels will move at the same time and in the same direction as the shelf. BTW, nice work there.
-- Bondo Gaposis
View MNgary's profile
MNgary
298 posts in 2413 days
#4 posted 01-10-2013 03:33 AM
It looks like the top cross-piece above the tile insets is 1/64 inch below the shelf, why not install the top shelf 1/64 inch from the wall, too. Using just one dowel (whatever) to fasten the top shelf should eliminaye movement problems.
-- I dream of a world where a duck can cross the road and no one asks why.
Fettler
#5 posted 01-10-2013 04:13 AM
The picture is before glue up… the pieces are just sitting next to each other on a non-flat walmart card table (my bench was a bit cluttered). The 1/64” shouldn’t be there, but we’ll see after glue-up (I make no promise for shotty workmanship =). I think i’m just going to glue the shelf to the corbels and side legs, but not the apron; then cross my fingers and see what happens in the summer.
View NiteWalker's profile
NiteWalker
2737 posts in 2573 days
#6 posted 01-10-2013 04:32 AM
Gluing it to the apron will get you the strongest glue bond.
That will be plenty strong, but if you want reinforcement, a few pocket screws through the apron into the shelf will keep it secure.
