Dry Lubricates for New Table Saw
Forum topic by kdc68 posted 01-09-2013 11:48 PM 1302 views 0 times favorited 24 replies Add to Favorites Watch
View kdc68's profile
kdc68
2692 posts in 2517 days
01-09-2013 11:48 PM
Topic tags/keywords: question
Asking advice for the best lubricate to use that won’t attract saw dust. While I wait for the correct legs to come from Grizzly (forum topic – New meaning to “not having a leg to stand on” with Grizzly), I thought I’d dry lube everything. The manual says white lithium grease and that’s fine. I’ve used it for a long time for other tools. But is there something better. Does Boeshield T-9 work good?
Items to lube:
Trunnion slides
Tilt leadscrew
Bevel Gears
Elevation Leadscrew and rail
I’d appreciate an opinion
Thank you
-- Measure "at least" twice and cut once
24 replies so far
View HorizontalMike's profile
HorizontalMike
7770 posts in 3154 days
#1 posted 01-10-2013 12:08 AM
The screws and gears need NO lubrication, and just a squirt of oil in the bushings is enough. You really don’t think you could wear out those gears by cranking the tilt and elevation… just sayin’...
kdc68
#2 posted 01-10-2013 12:34 AM
HorizontalMike – Well no I don’t think I’d wear them out. They appear heavy duty and I’m sure I will wear out before they do. The concern is more about to keep them running smoothly and prevent rust
117417 posts in 3817 days
#3 posted 01-10-2013 12:41 AM
Graphite is used in place of grease and many woodworking applications .
kdc68
#4 posted 01-10-2013 12:50 AM
a1Jim – Thanks. I’ll look into it
#5 posted 01-10-2013 12:56 AM
You can find it in a automotive parts house as speedometer cable lube or Through a woodworking supply as a router bearing lube .
kdc68
#6 posted 01-10-2013 01:18 AM
a1Jim – Yeah, router bearing lube…I may still have some Bostik bearing lubricate. Wonder if that would work?
Thanks again
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2313 days
#7 posted 01-10-2013 01:22 AM
I would advise the lube that grizzly recommends. It is not always important to use something that doesn’t attract dust. The design of the machine accounts for this. Use their recommendation. I have used the recommended high temp grease on all those parts on my unisaw and it runs great.IMO
-- Who is John Galt?
kdc68
#8 posted 01-10-2013 01:29 AM
joeyinsouthaustin and Rick L – thank you for your advice and the link
HorizontalMike
#9 posted 01-10-2013 01:31 AM
Wow Rick, that looks like a replacement for Bostik DriKote that I have been spraying on my TS blades and drill bits. I sure do not like paying nearly $20/can for the DriKote. I wonder if I could find it locally because shipping changes the game and the cost.
joeyinsouthaustin
#10 posted 01-10-2013 01:36 AM
HM and bostik just changed and re packaged the Drikote. Not sure if it is the sprayway stuff.
Found on amazon for 8.25 with free shipping. So there you go.
kdc68
#11 posted 01-10-2013 01:47 AM
HorizontalMike – FYI shipping from emisupply is just over $10. So about $17 or $18 for Sprayway with shipping
HorizontalMike
#12 posted 01-10-2013 01:57 AM
Joey,
I am not finding that same deal on Amazon. +$10/can and almost that in shipping. Got a better link for me?
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dautomotive&field-keywords=Dricote+&rh=n%3A15684181%2Ck%3ADricote+
HorizontalMike
#13 posted 01-10-2013 01:59 AM
KDC68,
Just found the same. Looks like going to the local WC is not a bad deal after all.
kdc68
#14 posted 01-10-2013 02:02 AM
HorizontalMike – Yep..get it when you want without waiting for UPS to drop it at your doorstep
joeyinsouthaustin
#15 posted 01-10-2013 02:13 AM
Sorry may have been misleading. It is a case price. but works out to that. It was listed as free shipping for prime members. but not now??
look here.
