| Forum topic by LSGss | posted 134 days ago | 516 views | 0 times favorited | 9 replies | ![]() |
134 days ago |
Hello all, I have a question about my watch box base. The base would be approximately 14” x 10”. 1.The sides of the box are 5/8” thick so first I was wondering what thickness should the base be? 2.I was told at this size the mahogany I plan to use would move therefore, would it be best the veneer plywood with hardwood veneer? Is there a way to still use hardwood and hide where it expands? 3. How thick should the veneer and plywood be? And what is the best way to incorporate it into the sides? Also when you adhere hardwood veneer to plywood, can that veneer move depending on the environment still? Sorry this is a lot of questions. I have a couple of box building books but I don’t feel like they address the topic well. Thank you. |
9 replies so far
#1 posted 128 days ago |
Hi Lenny. Welcome to LJ! -- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com |
#2 posted 128 days ago |
Hi Dan, thank you for the help. I do agree that 5/8” thickness will be to bulky perhaps 1/2” will work well.
Those are a couple of my drawings, im not a great drawer. Its a somewhat simple design. I plan on doing a hidden spline miter for the corners. I was going to put the base into a dado slot or rabbet the base and put that part into the dado slot. I prefer to use hardwood instead of veneer. I am making a gloss top with a thin frame. Thank you for your help. I really appreciate it. If you have a suggestion of other resources please let me know. Thank you again. Lenny |
#3 posted 122 days ago |
Lenny, I’m glad you sent email. This did not let me know even though it was marked to watch. -- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com |
#4 posted 118 days ago |
Yes this is a two layered box. The sliding drawer on the bottom and a fixed tray on top covered by a glass lid. I wasn’t sure about dimension for framing the glass top. I was going to do a hidden spline miter to strength the corner joints for the frame. I think I drew a side view in one of pictures, I have the it 2” H x 1” W x 14.75” L for the longer lengths. Let me know if you have any ideas about a good side for the frame. I think I will use 1/8’ glass. I have a general question about veneering. Cutting hardwood veneer, what is a thickness that would keep the veneered panel from moving and being able to be glued in around the entire parameter? Is there a way to make a solid wood bottom that is flush to the bottom of the sides? For example if the bottom has a rabbet that fits in the dado of the sides? Thanks again for the help, |
#5 posted 118 days ago |
The wood frame around the glass is going to be fragile due to its diminutive size in cross section, even with splines. No amount of thickness will keep a veneered panel from moving. If you veneer a panel it must be balanced. What you do to one side must be done to the other. No ifs ands or buts. Commercial veneers are measured in thousandths of an inch, 0.020-0.040. Home made veneers are tough to make at 1/16 =0.063. Then you need a press. Use four panels of particle board or MDF slightly bigger than the panel and glue them face to face in pairs. These make the top and bottom of a press that you can clamp together around the edges until the veneer glue sets up. A solid wood bottom could be made to fit as you suggest. Just allow for cross grain movement with deep dados and rabbets on the bottom panel edges parallel to grain. You’re gonna learn some things building this box, so get it done. Take notes for the next one! That’s all part of the fun. Got pictures? -- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com |
#6 posted 117 days ago |
Hey Dan, Would it be possible to make this kind of joint for the bottom. Could I use a real wood or only wood veneer on plywood? Would there have to be a space for “A” or “B” on the image. Thanks again. |
#7 posted 117 days ago |
Yes, you could use either veneered plywood or solid wood. Yes, you need space at A and B to allow for movement of solid wood, less for plywood veneer. Remember to allow for veneering both surfaces of the plywood bottom panel. That is a big MUST. This type of joint dado and rabbet is easy to do with hand planes or table saws. -- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com |
#8 posted 111 days ago |
How goes the war, Lenny? -- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com |
#9 posted 108 days ago |
It goes okay. I should have mentioned that I am a fourth year medical student on a busy rotation so I haven’t had time to do anything yet. I’ll defiantly let you know when I make some headway, i’m sure i’ll have more questions. Thanks and sorry about the slow reply. Lenny |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1535 |
3553 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2844 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
