Raised Panel Question
Forum topic by keathb posted 01-09-2013 03:47 AM 917 views 0 times favorited 2 replies Add to Favorites Watch
View keathb's profile
keathb
10 posts in 1966 days
01-09-2013 03:47 AM
Topic tags/keywords: raised panel
Hey guys, I am wanting to have some large raised panels in some bedroom furniture I am planning on building and need some advice on them please. My main concern is what material I should use. I am building the armoire from alder (probably) and on the sides I want a raised panel that will be 21” wide and 40” tall (minus the 2 1/2” wide stiles and rails).
Will I be forced to join two or more boards together, or are there options that I am just not coming up with?
Thanks in advance for all your knowledge
2 replies so far
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3283 days
#1 posted 01-09-2013 03:58 PM
You should not have any issues building those panels. I think alder would be a good choice. It is pretty stable, so the large panels should be OK. I don’t normally like to build single panels that big, but being part of furniture wil help. You will have to glue up stock to get the width. We use a butt joint which works fine, but you could do biscuits or dowels if you prefer.
Let me know if you need anything else
-- http://shepherdtoolandsupply.com/
View ducky911's profile
ducky911
237 posts in 2786 days
#2 posted 01-09-2013 04:36 PM
to router the edge even on a panal it needs to be dead flat…tough to get such a large panal dead flat. If not flat a router line will show an area of less depth in the route.
