Sanding Block Question
Forum topic by gfadvm posted 01-09-2013 12:57 AM 2802 views 0 times favorited 34 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2563 days
01-09-2013 12:57 AM
Topic tags/keywords: sanding blocks
I have built a bunch of sanding blocks (one for each grit) from some I’ve seen done by fellow LJs. Now the question is: should they have some sort of ‘padded’ base or should it be just bare wood? I’ve used that thin white floor underlayment as cushion for some in the past but don’t know what others recommend.
34 replies so far
View Grandpa's profile
Grandpa
3259 posts in 2548 days
#1 posted 01-09-2013 12:59 AM
I was taught to use a hard flat block on wood projects that have flat services. I have a couple of rubber pads but those are really made for sanding auto bodies so I keep them for that purpose.
View Handtooler's profile
Handtooler
1493 posts in 2005 days
#2 posted 01-09-2013 01:18 AM
Thanks Grandpa for the advise on the rubber sanding pad block. I’ll quit trying to use mine which I originally acquired to work auto body many years ago.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
Grandpa
#3 posted 01-09-2013 01:21 AM
I am not saying that is a bad thing to use the rubber pad but it does change to fit the contours you are sanding. Not like a rag but you know what I mean.
View John's profile
John
47 posts in 1946 days
#4 posted 01-09-2013 01:50 AM
It depends on what you’re sanding. Ideally, the shape of the sanding pad matches the shape of your work. If you’re sanding a flat surface, a hard, flat sanding block is good. It also allows you to use it sort of like a block plane and make faceted edges vs. a softer block which will round off corners. A hard backing also allows you to put more pressure and really hog off material with a coarse grade of sandpaper.
I use firm rubber pads for a lot of tasks, and my shopmade wood blocks for others. I don’t bother with any backing on the wood blocks.
View RussellAP's profile
RussellAP
3103 posts in 2159 days
#5 posted 01-09-2013 01:54 AM
If you think about it, any large surface you sand with a unpadded block will not conform completely to the surface being sanded. At least a couple layers of cardboard under the paper. You can get away with it on small pieces. I prefer ROS for large surfaces.
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2228 days
#6 posted 01-09-2013 02:00 AM
I picked up a piece of granite once I was going to use for a sanding block once, but alas it dissappeared before I got it back home, it was in a trash bin too…
The key is you want your block to be harder than the wood you’re sanding so that it won’t wear, for profiles I typically use my hands, as I can make my hand conform to pretty much any profile so…
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View Don W's profile
Don W
18561 posts in 2440 days
#7 posted 01-09-2013 02:01 AM
any i’ve made have been just wood (except these ) I didn’t put padding of any kind on them either, but I also haven’t really used them yet.
HillbillyShooter
5811 posts in 2165 days
#8 posted 01-09-2013 02:05 AM
1/16” cork is what I use per Karson, http://lumberjocks.com/projects/15783 . By the way, this was my introduction to LJ.
View vonhagen's profile
vonhagen
536 posts in 2238 days
#9 posted 01-09-2013 02:50 AM
before sandpaper the smoothing plane was used. i use 1 inch mdf or any scrap hardwood that is flat and contact cement the paper on, when the paper gets worn out i throw it away. when block sanding a flat surface you do not want any rubber or cork or anything soft as a backing. when contour sanding make a pattern block that fits your profile.
-- no matter what size job big or small do a job right or don't do it at all.
gfadvm
#10 posted 01-09-2013 03:09 AM
Thanks for all the replies. I had the feeling that my underlayment backing was causing my paper to snag and tear. I’ll try it without but I need to fill the hole in the center of the bottom or cover it with a thin strip of hardwood.
View jumbojack's profile
jumbojack
1673 posts in 2497 days
#11 posted 01-09-2013 03:14 AM
Since I make lot of boxes, I dont use a sanding block per-se. I glue a full sheet to a 15×20” piece of MDF and move the box across the full sheet. I have a full set 80, 100, 150, 180 and 220. It really helps to keep the flat parts flat.
View Clint Searl's profile
Clint Searl
1533 posts in 2234 days
#12 posted 01-09-2013 03:15 AM
I have two sanding blocks that are dimensioned such that I can hand hold a quarter sheet of paper. I faced one with truck inner tube and the other with 1/8” sheet cork.
View grizzman's profile
grizzman
7836 posts in 3176 days
#13 posted 01-09-2013 03:21 AM
i like the sheet cork also andy, but to each his own, i like a little bit of cushion that the cork gives…
-- GRIZZMAN ...[''''']
View bluekingfisher's profile
bluekingfisher
1247 posts in 2852 days
#14 posted 01-09-2013 09:01 AM
I would tend to use just the bare block Andy. Of course it could depend on what you are sanding I would have thought. Straight and flat, bare block, any coutours then some form of “padding” may be more appropriate.
Too much of a cushion may not sand the area flat and simply follow the contours of the piece, much like a smoother plane on a long wavy board.
-- No one plans to fail, they just, just fail to plan
gfadvm
#15 posted 01-09-2013 04:44 PM
I’m gonna try the plain wood backing and report back to y’all.
showing 1 through 15 of 34 replies
