Reducing the diameter of a dowell
Forum topic by bluekingfisher posted 01-08-2013 09:55 PM 1705 views 2 times favorited 19 replies Add to Favorites Watch
View bluekingfisher's profile
bluekingfisher
1247 posts in 2883 days
01-08-2013 09:55 PM
I’ve just come in from the shop as I need a little LJ advice. I’m building a tablesaw blade holder and need some 5/8” dowell stock or rather slightly less than 5/8” to slip through the arbor hole of the blade.
I need eight 3/4” lenghts of stock which I was hoping to cut from a 2’ lenght of 3/4” dowell stock and wondered if there is a safe way of reducing the diameter from 3/4” to 5/8”.
I was thinking of using a stacked dado head, raising it slightly above the table then rotating the dowell at right angles across the spinning blade, raising the blade until the desired size is acheived. I’m not so sure however if this is safe or feasible solution?
Any thoughts anyone? I don’t need absolute circular perfection, just something to slip through the arbor hole.
OR
Would it just be easier to admit defeat and use square stock with the edges chamfered??
Thanks in advance.
David
-- No one plans to fail, they just, just fail to plan
19 replies so far
View MrRon's profile
MrRon
4628 posts in 3147 days
#1 posted 01-08-2013 10:01 PM
Just use 1/2” dowel.
View Rex B's profile
Rex B
320 posts in 2154 days
#2 posted 01-08-2013 10:09 PM
Spin short pieces in the drill press like a lathe and take a file/rasp to it. Or use a chisel to make a makeshift pencil sharpener. Or, really, just do it the way you were talking about with the table saw. Clamp a piece of wood behind the dowel to prevent kickback; other than that it sounds safe.
-- Rex
View DKV's profile
DKV
3940 posts in 2408 days
#3 posted 01-08-2013 10:13 PM
Mrron has the obvious solution…
-- This is a Troll Free zone.
View Mip's profile
Mip
453 posts in 1982 days
#4 posted 01-08-2013 10:22 PM
Rex B has, what I think, the right answer in that you spin a short piece in the drill press and file it down. If you don’t have a drill press, use a hand held drill clamped to a table. If the hand held doesn’t have a 3/4” chuck, which I’m sure it doesn’t, thread a screw or bolt into the dowel end and chuck that into the drill. I wouldn’t use the table saw to do what you’re saying, I think it might be a little dangerous in my opinion.
View Jim Rowe's profile
Jim Rowe
1020 posts in 2216 days
#5 posted 01-08-2013 10:26 PM
David
You could make a 5/8 dowel plate and reduce the 3/4 stock you have available.
Jim
-- It always looks better when it's finished!
HillbillyShooter
5811 posts in 2196 days
#6 posted 01-08-2013 10:33 PM
You should be able to find 5/8” dowel. Here’s the link to Woodcraft’s dowel selection in the US: http://www.woodcraft.com/Product/2000667/36793/Maple-Dowel-12-Square.aspx
Otherwise, I’d either use the drill and reduce with a rasp or you could build an exotic jig and use a rabbiting bit in your router to reduce the diameter, such as a 1/16” rabbit for a 3/4” dowel or 3/16” rabbit for a 1” dowel (check out the jig I built and have used to crow or other wise route dowel, it’s the last four pictures: http://lumberjocks.com/projects/70532
View Brandon's profile
Brandon
4152 posts in 2855 days
#7 posted 01-08-2013 10:37 PM
They sell 5/8” dowels. I wouldn’t personally try any tricks on the TS. You might be interested in getting/making a dowel plate. Lie Nielsen makes one that is pretty sweet.
-- "hold fast to that which is good"
TopamaxSurvivor
18191 posts in 3580 days
#8 posted 01-09-2013 02:03 AM
I have some 5/8 scrap left from my daughter’s shoe tree. Probably cost more to import to England than they are worth ;-( You can have them if they are worth the cost of shipping.
View REO's profile
REO
928 posts in 1978 days
#9 posted 01-09-2013 03:07 AM
Jonathan hit the nail square with his suggestion! terrific post!
View gfadvm's profile
gfadvm
14940 posts in 2594 days
#10 posted 01-09-2013 03:12 AM
Jonathan to the rescue!!! AGAIN I gotta try that tomorrow! I’m very excited!!!
View jumbojack's profile
jumbojack
1673 posts in 2528 days
#11 posted 01-09-2013 03:20 AM
Yeah but can you come up with a way to turn 5/8 to 3/4. Now that would be a tip I’d like to see.
View FirehouseWoodworking's profile
704 posts in 3177 days
#12 posted 01-09-2013 05:16 AM
David,
I agree with Jonathan’s recommendation, but with a caveat. I would do it on a router table or shaper with a dado bit. Using a dado blade in a saw may leave grooves in your dowels, just as they do in the bottom of dados. A router bit wouldn’t leave such marks. Don’t know if that is important to your project or not. Good luck.
Cheers!
-- Dave; Lansing, Kansas
13594 posts in 3245 days
#13 posted 01-09-2013 05:39 AM
if you do the saw dado thing
just make sure the ‘outfeed’ side is higher than the ‘infeed’ side
by the difference in the dowel height
as it gets smaller after the saw cut
so it doesn’t drop suddenly
and catch in the saw
as it leaves the ‘infeed’ side
or better still
here is stefangs way
View oldnovice's profile
oldnovice
6543 posts in 3272 days
#14 posted 01-09-2013 06:09 AM
powow, why did you write this about gaming on this web site? It is totally out of place!
#15 posted 01-09-2013 06:19 AM
hes a spammer
been doing it for a couple of blogs
just hit the flag button
then again
and mark as spam
he will be removed
