| Forum topic by CantBurn | posted 131 days ago | 331 views | 1 time favorited | 5 replies | ![]() |
131 days ago |
Topic tags/keywords: wood size measure So, something struck me when I was looking at a cutting list. If it is listed as needing a 2X2 of say, cedar. And I have some left over 2X4’s of cedar. Is the original listed as an actual 2X2 or 1.1/2X1.1/2? So, if I try to rip my 2X4 at exactly 2inches, will it be right? Or would I have to rip it at 1.1/2? -- Chris-Woodstock, Illinois |
5 replies so far
#1 posted 131 days ago |
sounds like your plans use nominal size for the lumber dimension. 2×2 should in fact 1.5”x1.5” |
#2 posted 131 days ago |
usually 2×2 refers to nominal 2×2 material. if it refers to actual sizing it would be 2” x 2”. -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#3 posted 131 days ago |
It depends what it is. Many furniture plans use actual size because a lot pieces call for non standard thicknesses, i.e. legs that are 1 1/4” or table tops that are 7/8”. Those plans usually call for some way to thickness your lumber. Other furniture plans made from BORG construction materials will use nominal sizes on the cutting list, just depends on what you got. -- Bondo Gaposis |
#4 posted 131 days ago |
I would look for a notation on the plans that indicate nominal or actual sizes given. Lacking any guidance, I would be inclined to assume the cut list is referring to nominal sizes. -- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain |
#5 posted 131 days ago |
Thanks for the help. It was one of those moments were after all these years, I said “Wait a minute”. -- Chris-Woodstock, Illinois |
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1525 |
3543 |
15757 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6151 |
