Epoxy question
Forum topic by Dave Carlisle posted 01-08-2013 03:51 AM 1525 views 0 times favorited 12 replies Add to Favorites Watch
View Dave Carlisle's profile
Dave Carlisle
69 posts in 2332 days
01-08-2013 03:51 AM
I have made and sold quite a few Adirondack chairs this past year. I recently read an article where someone suggested putting an epoxy product on the bottom of the leg to better protect it from moisture. This is the only part that comes in direct contact with the ground. If I can better protect the chair legs with a coat of epoxy, I’ll be glad to try it. Any suggestions? Brand and where to purchase?? Thanks!!
-- Woodworking Principal
12 replies so far
View bondogaposis's profile
bondogaposis
5055 posts in 2528 days
#1 posted 01-08-2013 04:20 AM
West System Epoxy is a quality brand that boat builders use. Here is a link. It is not cheap, but quart would last a long time if you just use a little on the base of the legs where moisture will wick into the wood.
-- Bondo Gaposis
View fuigb's profile
fuigb
515 posts in 3134 days
#2 posted 01-08-2013 04:26 AM
I use a two-part Ace hardware brand. Maybe five bucks. Enough for a handful of chairs.
-- - Crud. Go tell your mother that I need a Band-aid.
View shipwright's profile
shipwright
8133 posts in 2975 days
#3 posted 01-08-2013 03:52 PM
A thick coating type of epoxy would not penetrate well and would be subject to wearing away by simple abrasion. A better choice would be a very thin penetrating epoxy sealer like S1 from System Three. I’ve used it for years and know of no other epoxy product that has the same characteristics.
View madts's profile
madts
1872 posts in 2517 days
#4 posted 01-08-2013 04:55 PM
+1 to Bondo Gaposis
-- Thor and Odin are still the greatest of Gods.
View grfrazee's profile
grfrazee
388 posts in 2316 days
#5 posted 01-08-2013 05:07 PM
My dad has inset PVC into the bottom of his adirondack chairs before and that seemed to work well (for use on a patio, at least). To do so, he routed out a recess about 1/4” deep in the bottom of the legs and screwed a piece of 1/2” or 3/4” PVC block into the recess. The PVC, being pretty much rot-proof, is the only thing in contact with the ground.
-- -=Pride is not a sin=-
View ChrisK's profile
ChrisK
2004 posts in 3258 days
#6 posted 01-08-2013 05:18 PM
A thin epoxy will penetrate the end grain a little. This will help prevent water from getting into the chair leg for a while.
-- Chris K
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3335 days
#7 posted 01-08-2013 05:46 PM
CA glue lasts for quite a while as well. It’s often used on rubber spider gaskets in a swimming pool multivalve where it is constantly submerged.
-- jay, www.allaboutastro.com
View JackieDeng's profile
JackieDeng
7 posts in 2084 days
#8 posted 03-07-2013 10:02 AM
Epoxy Rubber paint may be better Details on it can be found Epoxy Paint & Coating
Epoxy Coating Epoxy Moisture Barrier Sulfuric Acid Resistant Coating Epoxy Coating For Concrete And Steel Marine Structures
JackieDeng
#9 posted 03-07-2013 10:09 AM
http://www.epoxy-paint.cn Honest Paint & Coating
View crank49's profile
crank49
4032 posts in 3148 days
#10 posted 03-07-2013 02:36 PM
I’d have to go with Shipwright’s suggestion.
He uses the product and he builds boats, how much more relevant credibility would one need?
View KurtM's profile
KurtM
1 post in 2089 days
#11 posted 03-07-2013 03:10 PM
Epoxy has little abrasion resistance. I like the PVC idea for patios, gravel, and the like, and epoxy wicked into end grain for lawns and softer surfaces. The word “ground” covers too much territory to be useful for the original question asked, if you ask me.
Howdy fellers, 1st time post to LJ…..
What kind of boats does Shipwight build? I’m a cedar strip canoe and kayak builder, myself.
-- Damn the torpedoes, full speed ahead!
crank49
#12 posted 03-07-2013 09:12 PM
Well I know he built a fleet of harbor ferrys and a sloop or two but it would be better for him to tell you. You are both boat builders and I am not.
