L6 A20 DIY Extension Cord
Forum topic by mnik posted 01-08-2013 01:41 AM 961 views 0 times favorited 3 replies Add to Favorites Watch
View mnik's profile
mnik
58 posts in 2528 days
01-08-2013 01:41 AM
Topic tags/keywords: l6a20
Real quick. L6 A20: Wires are black white & green. Receptacle has X, Y and G connectors. I figure Green is G (ground). But what is X and Y?
-- Yeah, I'm probably over-thinking it. But that's my other hobby.
3 replies so far
View KGRRSteve's profile
KGRRSteve
28 posts in 1986 days
#1 posted 01-08-2013 04:45 AM
Doesn’t matter. Black and white are both hot legs, 220V potential to each other, and each leg is 110V potential to ground. Get the ground wire right and the others can go either way.
You are wiring 220 volt, correct?
-- Life has no remote. Get up and change it yourself.
View SqPeg's profile
SqPeg
15 posts in 1984 days
#2 posted 01-08-2013 05:47 AM
Correct X and Y can be two poles of a 220 circuit. Green is ground. You should be using 220V cord fittings to prevent using the cord on 120V equipment.
View mnik's profile
mnik
#3 posted 01-08-2013 01:01 PM
Perfect. Thank you.
