motor amps / hp question???
Forum topic by , posted 01-08-2013 01:15 AM 1227 views 0 times favorited 12 replies Add to Favorites Watch
View ,'s profile
2387 posts in 3781 days
01-08-2013 01:15 AM
OK, so we have 2 powermatic 3 hp shapers, and 2 Grizzly 3 hp shapers. I have been running my panel cutter on my Grizzly, the newer Grizzly we own. Our older Grizzly runs the stick, our Powermatics run the cope and door lip.
So we are building 77 Mesquite doors. We ran 30+ panels on our Grizzly today and it really struggled, more than in the past. Yes, Mesquite is hard, and I will also say my cutter is slightly sharper than a butter knife :). Not really, but point is the cutter is not extremely sharp. When the cutter was brand new I could raise panels in walnut in one single pass. We use 5/8” panels.
So I decided to look at comparison between the PM and Grizzly shapers. I quickly noticed the PM motors are almost twice as large in diameter as what the motors are inside the Grizzly shapers. I have looked and although they are all 3 hp motors, the Leeson motors inside the powermatics state they are 16.5 amps, whereas the Grizzly motors are stated to be 12 amps.
This leads me to believe our powermatic shapers are 25% stronger than the Grizzly shapers. Am I correct in this thinking.
Tomorrow I am taking my panel cutter to get it sharpened, then I plan to install it on the powermatic shaper.
Any information about my observations is welcome.
12 replies so far
View kdc68's profile
kdc68
2692 posts in 2511 days
#1 posted 01-08-2013 01:30 AM
Try this. Plug your volts and amps into the “Calculate Horrsepower”
http://www.engineeringtoolbox.com/electrical-motor-calculator-d_832.html
-- Measure "at least" twice and cut once
TopamaxSurvivor
18422 posts in 3910 days
#2 posted 01-08-2013 01:40 AM
You got it pretty well figured out Jerry. Especially the part about a sharp cutter ;-))
View ,'s profile
#3 posted 01-08-2013 02:04 AM
kdc68, the web site is cool, it appears the PM shapers are closer to 4 hp. The Grizzly shapers are closer to 3 hp.
TopamaxSurvivor, I do think I am on the right track… In fact, one shop danger is running dull knives / blades. Plus it runs the motors harder.
Thanks guys.
kdc68
#4 posted 01-08-2013 03:13 AM
Jerry – Thanks. I found the web site when I was finding the “true” horsepower of my 6.5 hp shop vac. At 6.5hp rating I’d have to be running the vac minimum 30 amps at 220 volt. Funny how they claim “peak” horsepower as actual horsepower.
View ,'s profile
#5 posted 01-08-2013 03:20 AM
Oh yeah, shop vacs are some of the worst offenders with that stuff. I have a 5 hp ridgid shop vac. Yeah right! My shop vac is no way 5 hp. Our Delta Cyclone has a 5 hp Leeson and no way are they in the same playing field :)
TopamaxSurvivor
#6 posted 01-08-2013 05:07 AM
kdc68, What is the actual voltage and amps for your “6.5” hp shop vac?
View MNgary's profile
MNgary
303 posts in 2651 days
#7 posted 01-08-2013 07:18 AM
In theory one can convert amperage to horsepower. And even in general usage one can state X amperage motor will probably produce Y horsepower. But not every horse in the coral can lift 3 horse thieves with a noose around their necks a foot off the ground in a second. Especially when you consider if the tree’s branch has either no bark, smooth bark, or a coarse bark. And worse, are we talking three horse thieves hoisted 1 foot by a horse or 12 lifted by 4 horses 4 feet in four seconds.
Add to that the puffery of sales literature and I’m convinced we’re comparing apples to prunes.
In a perfect world amps converts to horsepower – talking energy, but only energy. In a machine not all energy is solely converted to another label. Some is converted to heat (because of friction, inefficiecy of material used for motor windings, friction coefficient of a dull vs sharp cutter, and lots of other stuff) and not available for lifting the horse thieves.
I mean, I mean let’s quit thinking amperage determines power delivered at the end process and it will remain consistent over time. Especially when we don’t know if the manufacturer is talking about the first foot off the ground or the tenth foot.
I’ll now step off my soapbox having ineloquently shared my less than two cents worth of knowledge.
-- I dream of a world where a duck can cross the road and no one asks why.
TopamaxSurvivor
#8 posted 01-08-2013 07:45 AM
Now that they are all lying about HP, about all that is left for the layman to use for comparison is FLA (full load amps) on the name plate.
kdc68
#9 posted 01-08-2013 11:40 AM
TopamaxSurvivor – 11amps @ 120volts which according to the calculator is about 1hp.
TopamaxSurvivor
#10 posted 01-09-2013 02:51 AM
kdc68, That is about right. Long way from the claimed 6.5 hp, eh? ;-))
kdc68
#11 posted 01-09-2013 02:55 AM
TopamaxSurvivor – yeah….1hp with a clean filter maybe….1/2 hp with slightly used filter
TopamaxSurvivor
#12 posted 01-09-2013 02:58 AM
;-)) Well, a real 6.5 hp motor would draw about 70 amps on 120 volts. It would probably suck the hose you are using inside out!!
