Another Maple question.
Forum topic by Mark posted 134 days ago 456 views 1 time favorited 7 replies Add to Favorites Watch
View Mark's profile
Mark
134 posts in 143 days
134 days ago
I’m starting the assembly on a Mission style book case. After I had started the build I found out that Maple can be a bit of a bugger to finish. I don’t want it to dark and I’m concerned about the blotching thing, so the plan is to wipe on, wipe off a conditioner. Wipe on, wipe off an oil base stain (probably American Walnut) And cover with a water base varathane. This is what I’ve been told by my supplier. I will be using Varathane brand. Any thoughts would be appreciated. Thanks
-- Mark
7 replies so far
View gawthrrw's profile
gawthrrw
170 posts in 615 days
#1 posted 134 days ago
Mark, I just went through this. I did the same thing but was told to put down a thinned layer of oil varnish before the water based stuff. Make sure it cures before applying the water based varathane. It worked for me.
-- Rob, Kalamazoo, MI
View fladdy's profile
fladdy
63 posts in 1181 days
#2 posted 134 days ago
I used a wipe on/off conditioner on some maple with a light brown dye with alcohol. It turned out great. I think the conditioner will be a big help to prevent the blotching.
-- Fladdy
runswithscissors
608 posts in 193 days
#3 posted 133 days ago
This is one of the reasons I use stain as rarely as possible. If I want walnut look, why not walnut wood? Maple is a beautiful wood finished natural. When I was doing our kitchen cabinets out of oak (a random mix of red and white, as 95% of it was recycled wood), the granite installer asked, “what stain?” “None,” I answered. His jaw dropped. It seems to be an automatic response nowadays to want to color wood something other than what it is. Now my dad, he didn’t have a lot of money and used mostly ponderosa pine. He stained everything, mostly walnut. And what did it look like? Walnut stained pine. And blotchy, as you might expect. Eventually he started using poplar, and I admit it isn’t a very pretty greenish yellow. But most people paint it, I suspect.
I guess pretty soon we’ll be seeing inquiries about how to bleach walnut to make it look more like pine.
Sorry if this seemed to turn into a rant. I just am not a fan of stain, as you can probably tell.
View Austons_Garage's profile
Austons_Garage
37 posts in 199 days
#4 posted 133 days ago
You could use a conditioner, or you could use a 1/2 lbs cut shellac sealer. The shellac will probably do a better job of preventing blotching. It’s well worth the time and effort to use a dye instead of an oil stain on maple if you are headed to walnut on maple. Seal between color and topcoat.
View NiteWalker's profile
NiteWalker
1473 posts in 745 days
#5 posted 133 days ago
Skip all the hooplah with stains. Use zinsser sealcoat tinted with transtint dyes (dark vintage maple looks great on maple), then coat with your water borne clear. No muss, entire finishing schedule done in 1 or 2 days instead of weeks.
View ducky911's profile
ducky911
163 posts in 958 days
#6 posted 133 days ago
maple does note take stain…but you can dye to any color….charles does sell a good conditioner
View Mark's profile
Mark
#7 posted 133 days ago
Thanks for all the suggestions gents. Lots to choose from.
-- Mark
