15/16" forstner or router bit?
Forum topic by ChesapeakeBob posted 01-07-2013 09:02 PM 1440 views 0 times favorited 10 replies Add to Favorites Watch
View ChesapeakeBob's profile
ChesapeakeBob
367 posts in 3603 days
01-07-2013 09:02 PM
Topic tags/keywords: forstner
I recently needed to drill shallow 15/16” holes in a piece of 3/8” wood (back of clipboard project and bottom of a model boat stand). I had the Irwin Speedbor bit in my drilll when I realized that the tip of this type of bit would come through on the other side. A quick look on the net did not reveal any forstner or router bits in a 15/16” diamater. Any thoughts? As long as bit does not penetrate the other side, I can make it work. Has anyone ever tried grinding off the tip of a Speedbor type bit?
-- Chesapeake Bob, Southern Maryland
10 replies so far
View Dusty56's profile
Dusty56
11822 posts in 3808 days
#1 posted 01-07-2013 09:10 PM
We just had this discussion regarding Forstner bits : ) I’ll try to find it for you.
Here it is..hope this helps : )
http://lumberjocks.com/topics/28658
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3278 days
#2 posted 01-07-2013 09:11 PM
Use a circle template and straight pattern bit for the router. Set the bit depth appropriately.
To create the template, use a larger forstner bit, sized to give you the right circle to compensate for the bit bearing. You might have to experiment, but it will yield a dead flat hole.
-- jay, www.allaboutastro.com
404 - Not Found
2544 posts in 3089 days
#3 posted 01-07-2013 09:14 PM
or, use your forstner bit to make a template for a top bearing guided router bit.
Dusty56
#4 posted 01-07-2013 09:15 PM
Here’s a router bit …took me three clicks on the mouse to find it : )
http://www.sears.com/amana-45252-cnc-straight-plunge-router-bits/p-SPM5102774901P
View sprucegum's profile
sprucegum
324 posts in 2117 days
#5 posted 01-07-2013 09:21 PM
Almost any bit will work in a drill press without its pilot or feed worm. I often use large hole saws without the center drill in my drill press just be sure the work is well clamped. If you are using a hand held drill first drill a hole in a piece of scrap with a piloted drill then clamp it to your work and use it for a guide. I have done this before to enlarge a hole where there is no wood in the center to hold the pilot. Never have tried it with a flat spade type speed bore they may be a little harder to make follow your guide block. I would look around for a brad point drill some of them have a pretty short point and they will make a nicer hole than your speed bore.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
Cosmicsniper
#6 posted 01-07-2013 09:32 PM
Actually, that’s what I meant to say, Renners. I made a jig the other day using guide bushings, so I had that on my mind. With a pilot bearing, you’d just drill a hole with the same bit size.
View Lee Barker's profile
Lee Barker
2170 posts in 2970 days
#7 posted 01-07-2013 09:42 PM
Two suggestions:
1. Grind the pilot way down on a spade bit. Grind it narrower to your number.
2. Purchase a set of 1/16” forstners. Here is one possibility
I have a 6 piece set which I bought several years ago, not sure where. I am amazed at how often I use these.
Kindly,
View gfadvm's profile
gfadvm
14940 posts in 2810 days
#8 posted 01-08-2013 03:38 AM
I needed a 2 1/2” flat bottomed hole 1/2” deep for my candy machine and didn’t want that pilot divot in the center and didn’t want to buy a big Forstner and grind on it. Solution: Used a holesaw to make a template and taped it to the workpiece. Then used a pattern bit in my router table to make a perfect hole. Pretty much what Cosmicsniper and Renners suggested.
ChesapeakeBob
#9 posted 01-08-2013 07:16 PM
Thanks everyone for your suggestions and help with this.
Dusty56
#10 posted 01-08-2013 11:52 PM
You’re welcome. You’ll have to let us know what you decide to use : )
