Bench length without sagging
Forum topic by Manitario posted 01-07-2013 07:46 PM 9212 views 0 times favorited 9 replies Add to Favorites Watch
View Manitario's profile
Manitario
2629 posts in 2846 days
01-07-2013 07:46 PM
Hey all, I’m building a bench out of a slab of elm to compliment a elm slab trestle table I’ve made for the dining room. The slab is ~2 1/2” thick and about 75” long. I’m just curious if it would be strong enough to support 4 people without bowing in the middle or if I’ll have to design some sort of support for the middle of the span. In general, is there any sort of guidelines/calculator as to how long you can make a bench span before the weight of people sitting on it will bow it?
thanks!
9 replies so far
View Dusty56's profile
Dusty56
11819 posts in 3651 days
#1 posted 01-07-2013 08:23 PM
How far in from the ends do you plan on placing the legs ?
If they’re going to be at the very ends , I would put a support in the middle just to ease the stress on the ends and for stability. JMO : )
Manitario
#2 posted 01-07-2013 08:29 PM
I was planning on putting the legs within about 6” of the ends…also considering making two shorter benches instead of one long bench…
Dusty56
#3 posted 01-07-2013 08:39 PM
I think the two benches would be better in the long run : )
View DKV's profile
DKV
3940 posts in 2467 days
#4 posted 01-07-2013 08:40 PM
Rob, try the below. It’s for shelves but aren’t benches nothing more than shelves for people? Lot’s of people use the sagulator. 2 or 3 inch edges run along the length of the bench also help with load.
http://www.woodbin.com/calcs/sagulator.htm
-- This is a Troll Free zone.
Manitario
#5 posted 01-07-2013 08:41 PM
you’re probably right…just twice the amount of work!
View DKV's profile
DKV
#6 posted 01-07-2013 08:44 PM
Dusty56
#7 posted 01-07-2013 09:07 PM
I’m just thinking about creature comforts…say you have a couple of children and a couple of adults seated. The kids would need to sit closer to the table than the adults which might make for some uncomfortable dining : )
Manitario
#8 posted 01-07-2013 09:45 PM
Thanks DKV; that is exactly what I was looking for. Interestingly, the sag is quite a bit less than I expected, even with a presumed 200lb load/foot the sag in the center is only 0.1”. Dusty, your point is well taken though, a bench with 4 people on it is inconvenient at best, although rather convenient for me to make…
Dusty56
#9 posted 01-07-2013 09:54 PM
What’s four more legs in the scheme of things ? LOL
I wasn’t really concerned with the sag factor as much as I was with the future enjoyment of your projects.
I used to have as my signature ; “Do what you want to do , you’re going to anyway” : )
