How to clean an HVLP gun
Forum topic by dakremer posted 01-07-2013 06:42 PM 2438 views 1 time favorited 24 replies Add to Favorites Watch
View dakremer's profile
dakremer
2672 posts in 3092 days
01-07-2013 06:42 PM
I just got an HVLP gun (woodcraft). I want to try using it for the first time. I plan on spraying some wax free shellac. It says on the can to clean shellac up with Denatured alcohol. So after i’m done spraying…what is the process of cleaning the gun??
How long can I keep the shellac in the gun before cleaning it out??
Thanks a lot!
-- Hey you dang woodchucks, quit chucking my wood!!!!
24 replies so far
View pintodeluxe's profile
pintodeluxe
5662 posts in 2813 days
#1 posted 01-07-2013 06:52 PM
There are some good videos on youtube on this topic. I usually empty the gun and run some thinner through it between coats. The most useful tip I can give you is this…
Unscrew the front nozzle from the gun and soak it in thinner (denatured alcohol in your case). This will keep the tiny apertures from clogging.
If the gun ever quits spraying – check the vent in the lid of the fluid reservoir. If it clogs it will stop you cold.
The Wood River gun is a good one, I sure like mine.
dakremer
#2 posted 01-07-2013 06:54 PM
so even if you’re only waiting an hour between coats – you still empty it and run the denatured alcohol through it?
View Jim Jakosh's profile
Jim Jakosh
20489 posts in 3106 days
#3 posted 01-07-2013 07:05 PM
Doug, do you have to wait that long? I thought it dried in a few minutes!
View Woodbum's profile
Woodbum
812 posts in 3066 days
#4 posted 01-07-2013 07:16 PM
Follow the instructions that came with your gun or…Dump all of the spray from the cup and wipe out the excess. Then run about a 8 oz of the recommended solvent through the gun at low pressure. Clean the cup well and fill 1/2 full with clean solvent. Then I disassemble the gun and soak the needle, orifice etc in the solvent for a few minutes and clean all parts and the gun body well with the brushes etc that came with your gun. If you didn’t get any, buy a good HVLP cleaning kit. Dry all parts with the warm air from the turbine and reaasemble. I keep my gun in a large plastic bag that is slightly vented. Not saying this is the proper way, but it is the way I was taught. An HVLP factory rep told me that anyone can use an HVLP and get good results once. After that, your results depend on how well you clean your gun and set it up for the finish that you are spraying with the proper needle and orifice and at the proper pressure and air/finish balance to maximize the atomization. From personal experience, I have found that thinner is better than thick finish so I thin it with solvent or retarder for lacquer. This process works for me. Good luck, and I’ll leave you with the caveat that successful HVLP finishing is not as simple as it sounds. Once you get it down, you will love it. Practice, practice and practice some more. And experiment before spraying your finished work.
I would clean the gun as soon as you are done spraying. I will leave spray in the gun for short periods between coats. That length of time is dictated by heat and humidity and the type of finish being used. If the finish dries in the gun, your cleaning just got more difficult
-- "Now I'm just another old guy wearing funny clothes"
dakremer
#5 posted 01-07-2013 07:25 PM
Jim, i guess i’m not sure how long you have to wait for dewaxed shellac with spraying? The bottle says 1 hour. Maybe its different when you spray it?
Woodbum – the instructions were absolute garbage – it had like 2 sentences on cleaning – and they didnt say much. Thanks for the info!
View Earlextech's profile
Earlextech
1161 posts in 2691 days
#6 posted 01-07-2013 07:29 PM
Clean at the end of the day. Break down the gun to clean parts individually. They shouldn’t soak any longer than the time it takes to clean it, about 15 minutes.
If you take an extended break, fill the cup with finish. If there is more air in the cup than finish, it will dry, if there is more finish in the cup than air, it will not. When you come back from your break you will find a booger of dried finish on the tip of the nozzle. Scrape it off with your fingernail and start spraying.
dakremer
#7 posted 01-07-2013 07:31 PM
so if i’m spraying dewaxed shellac – how long should i wait between coats?
View lumberjoe's profile
lumberjoe
2899 posts in 2249 days
#8 posted 01-07-2013 07:34 PM
Until it isn’t tacky any more. It depends of a lot if different things so a time estimate would be from mere minutes to a few hours (humidity, temp, size, amount applied, etc)
dakremer
#9 posted 01-07-2013 07:41 PM
makes sense
dakremer
#10 posted 01-07-2013 07:43 PM
Thanks for the youtube tip – i’ve tried look up HVLP on youtube before with no luck. This time i typed in “cleaning a HVLP” and got tons of stuff!! WTF?
Thanks for the help guys!
If you have any other tips – i’d appreciate it!
View bullhead1's profile
bullhead1
228 posts in 2249 days
#11 posted 01-07-2013 07:52 PM
I got a few of extra pots with screw on lids for my hvlp gun. One I use for cleaning and storage. If I have to wait for any extended period, I just change out the pot and run a little thinner or soap and water if using a water based product. If you don’t the tip will gum up. I don’t have any problems with mine. Had almost a year and haven’t had to tear it apart yet. I have a couple of the pots with the finish I spray most and the lids on they have seemed to keep ok.
pintodeluxe
#12 posted 01-07-2013 08:01 PM
In answer to your question, yes I empty the cup and run an ounce of thinner through the gun between coats. I remove the screw-off nozzle, and drop it into a tupperware container of solvent. This solvent gets re-used for cleaning only. That procedure takes about 2 minutes, and has saved me a lot of headaches. Keep in mind that with that gun, you may only need to spray two coats so the work progresses quickly.
View NiteWalker's profile
NiteWalker
2737 posts in 2577 days
#13 posted 01-07-2013 08:22 PM
I’ve been spraying sealcoat (dewaxed shellac) followed by crystalac super premium for almost 2 years now. The sealcoat dries in 15-20 minutes; I usually recoat in 30.
I clean the gun at the end of the day’s spraying, though I have “accidentally” left finish in the gun overnite with no ill effects. This happens most when I’m spraying a coat late in the evening and then another early in the morning.
For cleaning: run some solvent through the gun, then take the air cap, nozzle and needle off and place those in solvent to soak. Wipe the inside and outside of the cup and the outside of the gun body with a rag wet with solvent. Back to the soaking parts, use a small brush to make sure there’s no finish in the air cap holes or the nozzle. Reassemble the gun, and run a bit more solvent through it to make sure everything’s working properly.
I learned spraying from jeff jewitt’s spray finishing made simple book and dvd. It’s an excellent resource. Another is andy charron’s spray finishing.
View Dez's profile
Dez
1166 posts in 4077 days
#14 posted 01-07-2013 08:24 PM
Earlextech has it it right!
-- Folly ever comes cloaked in opportunity!
dakremer
#15 posted 01-07-2013 08:45 PM
Thanks guys!
