Aluminum Foil for Glue-ups?
Forum topic by jasoncarpentry posted 133 days ago 549 views 0 times favorited 11 replies Add to Favorites Watch
View jasoncarpentry's profile
jasoncarpentry
78 posts in 822 days
133 days ago
I use a “mini-table” (24” x 14”) w/ a front fence to glue up laminates for my cutting boards. I’ve been using a wax-paper liner to prevent the glue (Titebond II or III) from sticking to the table, and it works OK, but sometimes it bunches up and gets in the way, and it’s always messy to peel off the finished piece.
So I had an idea: Why not use aluminum foil instead? Has anybody tried glue-ups w/ this type of backing? If so, what results did you get? Does it peel off cleanly, unlike wax paper? I don’t want to mess up a painstaking laminate, or knick my planer blades, because of residual metal on the workpiece.
-- Jim in Tennessee
11 replies so far
View crank49's profile
crank49
2284 posts in 1139 days
#1 posted 133 days ago
Aluminum foil residue should not be too rough on planer blades.
BUT, no glue on earth will stick to polyethylene. The thin stuff, like Glad Wrap, can get wrinkles and the glue might trap the wrinkled sheet in folds that harden, but you can avoid this by using the thicker sheets.
I use 2 mil thickness like the type used for temporary tarps and under concrete.
Even peels off of epoxy and Gorilla Glue.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View AlaskaGuy's profile
AlaskaGuy
255 posts in 477 days
#2 posted 133 days ago
Change your table top to something like Melamine and you wont’ need to fuss with wax paper or foil. Glue pops right off melamine with little effort.
View Dusty56's profile
Dusty56
10511 posts in 1856 days
#3 posted 133 days ago
Odd that the glue would stick to wax paper. What brand of paper are you using ?
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View crashn's profile
crashn
507 posts in 633 days
#4 posted 133 days ago
Aluminum foil has a very thin sheen of oil on the foil, a left over from the manufacturing process. Might interfere with future finishing attempts. I like either a polyeurothane or malamine top for my glue ups. Pops right off.
-- Crashn - the only thing I make more of than sawdust is mistakes
jasoncarpentry
#5 posted 133 days ago
Dusty & others-
I’m using name-brand wax paper (Cut-Rite). BUT the way I do my glue-ups, the piece can sit on the table top for several days, long enough for the glue to harden completely. If I could make a complete laminate in one day and then remove it from the table, I think the wax paper would peel off nicely.
I’m working on ways to speed up the process!
-- Jim in Tennessee
Dusty56
#6 posted 133 days ago
Must be the time thing..I also use the Cut-Rite brand : )
Sounds like Melamine would be the answer for your needs.
I picked some up at my local lumberyard. It was a damaged 16” wide piece that they sell for shelving and storage closets.
Just one example here.
http://www.homedepot.com/buy/1-x-2-x-4-white-melamine-shelf-252297.html#.UOslm-RZXKh
View teejk's profile
teejk
971 posts in 853 days
#7 posted 133 days ago
try butchers freezer paper (waxed one side)...available at Wally World. It’s got more substance than plain old wax paper.
View pintodeluxe's profile
pintodeluxe
1739 posts in 981 days
#8 posted 133 days ago
1+ Alaska Guy’s comment. I do glueup on a sophisticated platform: two sawhorses with a piece of 3/4” melamine on top. Let the glue fall where it may. It pops off easily with a putty knife of chisel.
The problem I have with wax paper – and I don’t think foil would be any different – it often doesn’t let the glue dry.
View woodsmithshop's profile
woodsmithshop
918 posts in 1714 days
#9 posted 133 days ago
I lay a sheet of visqueen on top of my bench before doing a glue up, I also lay a sheet on top of my clamps to keep the glue from sticking to them.it makes clean up much easier , you just don’t want to leave your project lay on top of the plastic sheet very long or the glue will not dry.
-- Smitty!!!
View Minimalist's profile
Minimalist
1 post in 130 days
#10 posted 125 days ago
I’m not sure if it will work on your table top but I have used strips of packing tape on my cauls and have never had any glue stick to them. You know, that shiny baby-poop brown stuff that is an exercise in frustration to peel the working end up. Might be a simple fix until you can change to the melamine table top.
-- I like rocks; they're really good a being what they are, and darned handy in a fight.
View NiteWalker's profile
NiteWalker
1473 posts in 745 days
#11 posted 125 days ago
Wax paper wasn’t working for me so I use plastic sheeting now (the thick kind used for drop cloths).
