Drawer Vacuum?
« back to Coffee Lounge forum
Forum topic by CaptainSkully posted 80 days ago 114 views 0 times favorited 5 replies Add to Favorites
View CaptainSkully's profile
CaptainSkully
92 posts in 85 days
80 days ago
On the A&C Gentleman’s chest I just finished, I’ve noticed that the fit of the large bottom drawers causes a considerable amount of suction behind them, between the back panel when the drawer is pulled out. I was thinking of relieving this with a 2” Forstner bit to allow air to flow more easily in and out, which should make the action of the drawers much easier. It wouldn’t be seen from the front at all. Any thoughts on this matter? Thanks!
-- You can't control the wind, but you can adjust your sails
View Mark Shymanski's profile
Mark Shymanski
709 posts in 239 days
80 days ago
I am impressed that you got such a tight fitting on your drawers that they vacuum. I searched out your project and am really like the chest and how you explained all the trials and tribulations.
Could you cut a slight notch along the top of the back of the drawer to let the air through and also be not as noticeable as a hole drilled in the back? It would not take too much of a notch to let sufficient air through…
-- ....next big purchase is wood for the next project, Mark
View Tim Pursell's profile
Tim Pursell
216 posts in 309 days
80 days ago
Don’t do it! Craftsmen spend a lot of time & effort to get just that effect. It is a sign of top quality work! The reason it is desirable is that it will limit the dust in the air from getting in & getting your clothing dirty.
-- http://www.grandprairiewoodworks.com
View Jojo's profile
Jojo
364 posts in 499 days
80 days ago
Congrats Mark, that’s a sign of great craftsmanship!
I wouldn’t go the Forstner bit way though, maybe it is too drastic. I have torn feelings with this issue. As Tim says it is a mesure of quality but it lessens the usability in the day to day, making the experience somewhat inconfortable if the force to apply is too strong. Maybe a regular bit hole placed in the bottom of the case would help relief that force a little while not being visible at all. Methinks the trick is to achieve some balance between that great vacuum feeling and the ease of use for everyday.
By the way, I loved your project.
-- Jojo, shopless in Kyoto · http://www.japanese-woodworking-tools.com/ · http://twitter.com/japanesetools
Mark Shymanski
80 days ago
Ummmm, the great craftsmanship is CaptainSkully’s I am just an admirer of such quality and striving one day to be there :-) I agree Jojo that Tim’s suggestion of a a hole in the bottom of the cabinet to ease the air resistance is probably better then the notch suggestion I made.
View Jojo's profile
Jojo
77 days ago
Euh… sorry to disappoint you Mark, the hole in the bottom wasn’t actually Tim’s suggestion but mine. :o)
I have to say though, that relieving the top of the drawer’s back panel was also my first idea! Great minds…
Bookmark And Share This Page
