| Forum topic by Odiferous | posted 137 days ago | 461 views | 0 times favorited | 7 replies | ![]() |
137 days ago |
I’m a novice trying to make shop out of one garage bay, and I’m trying to decide where to start. In addition to the standard 10’x20’ space, there’s a raised 6’x9 1/2’ area that houses the water heater and an old garage workbench. I already have half the rock off of this wall from installing the shop’s sub panel, so I’m trying to decide what I want to do with this space to determine whether I put up new sheetrock, or just pegboard on the studs, or what.
What should I do with the extra area? |
7 replies so far
#1 posted 137 days ago |
Go to grizzly.com, they have a shop layout tool. I put plywood on the walls. I can hang anything anywhere without worrying about finding a stud. ( just make sure it meets code) I poly’d mine, but I hate paint and like wood. There is another active thread and every one else recommends white paint. yuk….. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#2 posted 137 days ago |
I would build that area in and either make it a small room for finishing or put your dust collector in there if you have one. -- Rob, Kalamazoo, MI |
#3 posted 136 days ago |
Nevermind… Didnt see that the water heater was in there. Wouldnt want any explosions.. -- Rob, Kalamazoo, MI |
#4 posted 136 days ago |
I had a similar set up in my last shop only there was no water heater there. I popped for about $220 and put in a raised plywood floor throughout the shop to make it all one level in order to best utilize this space. I liked it this way so my roll around office type chair worked well. On the walls I put up 1/8” Masonite with white gloss finish and screwed it to the studs. Cheap, white walls, no painting, easy to locate studs (screw heads) for hanging anything on the walls, demountable, and I put the wiring on the outside of the walls in conduit because it looks nice and easy to modify if needed. -- In God We Trust |
#5 posted 136 days ago |
Looks like if you move the car out you’d almost double your shop area :o) |
#6 posted 136 days ago |
I would hang some ply and make some clamshelled cabinets. You can effectively triple or better you utilization of wall space area by using pegboard clamshelled on swing out doors inside of cabinets. Another thought would be to install a sink in there .Guys who have utility sinks in their shops swear by them. Should be a drain near-by that water heater. And you still would have room for a mobile workbench or a few other mobile tool stands in that space. And personally I don’t care for shelving units that stand on the floor. In small shops floorspace I would also agree that bringing up the floor to be level with that part would be good. But that |
#7 posted 136 days ago |
I’m already planning to do all of the electrical in conduit along the ceiling, then run a few drops down the outside of the wall. I did put in a flush mount sub panel though, so I could hinge a piece of pegboard or something in front of it and not waste the limited wall space. My plan is to eventually build a carport onto the front of the garage and kick the car out—but first, I’ve got to clock a lot more woodworking hours. I hadn’t seriously considered a sink for a wood shop, but I can see the appeal for finishing cleanup. The water heater doesn’t have a drain, but the washing machine is on the other side of that 6’ wall, so I could probably put a utility sink right in front of the water heater. I’m thinking more and more that the sad old workbench is getting ripped out and I’m putting ply up. |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15797 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
