Filling cracks
Forum topic by Maximillian posted 01-06-2013 07:12 PM 1067 views 0 times favorited 10 replies Add to Favorites Watch
View Maximillian's profile
Maximillian
84 posts in 3184 days
01-06-2013 07:12 PM
Topic tags/keywords: question finishing joining
Hi
I have been making end-grain cheeseboards for christmas gifts, which have been a geat hit (see my last project).
Unfortunately, the one I retained for myself has developed a large crack, whhich goes right through the end-grain block. It’s surprising that it has cracked across several of the blocks. It’s as though a corner of the board has broken off (although it is retained by the edge clashings).
I want to fill this crack in and am not sure what to use, as the blosks are well-oiled with mineral oil.
Would epoxy resin (Araldite) be better than cyanoacrylate, or is there something better to ujse.
I hope that my gifts haven’t suffered similar fates.
Cheers
Max
-- Max, New Zealand
10 replies so far
View AandCstyle's profile
AandCstyle
2977 posts in 2160 days
#1 posted 01-07-2013 12:58 AM
Max, I can’t really tell from the pix, but is it possible that you have the end grain portion of the board captured in a frame and that the end grain section has expanded across the grain enough to cause the crack? If that is the case, I would try the epoxy with sanding dust or a very black pigment mixed into it. The saw dust will make the crack less noticeable and the black will highlight the crack. This is an aesthetics issue, so do which ever you prefer. Whatever you decide to do, do some testing first. Epoxy is somewhat flexible, so it might accommodate the woods normal movement if that is the cause of the crack.
Let us know how you make out. HTH
-- Art
View lumberjoe's profile
lumberjoe
2894 posts in 2151 days
#2 posted 01-07-2013 01:00 AM
View Dan Krager's profile
Dan Krager
3844 posts in 2137 days
#3 posted 01-07-2013 01:34 AM
I grew curious years ago why the end grain cutting block at the butcher shop never cracked. I asked the owner of it about it and he said once a year he melts paraffin into the block and scrapes it off. He had done that since it was new. Since there is a butcher block mfr near hear, I asked if that was a good method. The response was that it was indeed a very food friendly method of preserving the block. Now these blocks were 6” thick or more. I asked the mfr how they treated the blocks they knew were headed for food use, and they declined to be specific. ??? OK. Did they treat the bottom same as top? “Oh yes, for sure”.
But from that and some experimenting on my own, a good soaking in melted paraffin will almost 100% guarantee that the end grain assembly will be stable and safe forever. It is easy to maintain too.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com Just when you figure out where things are in the hardware store, they rearrange the store.
Dan Krager
#4 posted 01-07-2013 01:35 AM
Oh, I meant to ask. Are my eyes failing? I didn’t see any pics. ???
DanK
Maximillian
#5 posted 01-07-2013 02:10 AM
Thanks for the help guys
Art, I wondered if my 360 degree “frame” around the end grain piece may have been the cause of the problem.
Dan, by paraffin do you mean paraffin wax that candles are made from? Does that penetrate the grain?
No, there are no photos, as I can’t figure out how to use the photo bucket thing. However, if you look at my projects or type “end grain cheeseboard” into the LJ search box you can see a photo of one I made. That isn’t the cracked one and uses only one type of wood in the end-grain section
Cheers
Max
-- Max, New Zealand
TopamaxSurvivor
18189 posts in 3579 days
#6 posted 01-07-2013 02:35 AM
Dan, Is paraffin all that is used? No mineral oil or anything else?
View USMC6531's profile
USMC6531
42 posts in 2563 days
#7 posted 01-07-2013 02:44 AM
Max, if you have a border around the cutting board that is most likely the cause of the crack, because it fails to allow for expansion of the wood, leading to stress and warping or cracking of the wood. Try removing the border and then following the above link posted by lumberjoe, the method may help fix your problem. Good luck!
Dan Krager
#8 posted 01-07-2013 02:55 AM
I use straight melted (double boiler) paraffin (candle wax, canning wax, even bees wax) on wood that has been heated to about 150 degrees in oven. Paint it on until it stops soaking in. Sometimes I just dip the piece and let it soak. Container size is an issue sometimes. Experiments on penetration show that capillary action draws the melt more than an inch into end grain, so a 2” thick end grain cutting board can be “plasticized”. I do not thin it as the stuff is oily to begin with and when melted fully is about the consistency of water. By filling the pores completely this way, the board is more likely to stay clean and is quite water resistant. Soapy dish water does remove some of the wax when washed, so suggest not using soapy water. Just wipe it clean or scrape it.
Remember that melted wax is volatile and wax vapors should be treated as a potential explosive risk, so ventilation is necessary for “big” jobs. Never put the stuff in the oven or in a pan directly on heat.
Definitely no long grain border!
DanK
Dan Krager
#9 posted 01-07-2013 03:09 AM
Yah, Max, the photobucket thing is a bit persnickity with their new beta version. It’s still pretty straightfoward.
1. Go to photobucket page and capture the address of the pics. Either highlight and copy the URL in the bar at top or use their “direct link” copy location button. Net result is URL in copy buffer.
2. In your post click on the chain link and paste the URL or on the IMG button, select “from web” option and paste the URL.
That should do it if it’s going to work. But then everything is backward or upside down in your part of the world, yes? LOL
DanK
View Dallas's profile
Dallas
3599 posts in 2390 days
#10 posted 01-07-2013 03:12 AM
Just for FYI, I believe mineral oil and paraffin are the same thing and pretty much inert.
I always use a mix of mineral oil and beeswax to seal a board.
Just another FYI, 2 tablespoons of beeswax will solidify a 16 ounce bottle of mineral oil to a little harder than the consistency of Johnson’s Paste Wax when warmed in a double boiler or the nuke and then cooled.
