Forum topic by COMO | posted 01-06-2013 04:11 PM | 2514 views | 0 times favorited | 15 replies | ![]() |
I am getting ready to start a build for our office. It will involve a murphy bed, built in desk, and built in storage. My wife would like it to be white with wood tops. I figured since It will be getting painted MDF would be the best way to go. Does this sound ok? Also what would be the most durable way to paint the MDF. I was thinking of looking at the rustoleum cabinet kits. |
15 replies so far
#1 posted 01-06-2013 04:15 PM |
If you have the equipment spraying is the best way to go. -- https://www.artisticwoodstudio.com/videos wood crafting & woodworking classes |
#2 posted 01-06-2013 04:21 PM |
I’ve had good results with priming the MDF using Zinsser BIN and then used General Finishes Enduro Var Poly that was tinted white as the top coat. It came out great (look at my projects, well, the only one :) As Jim said, I sprayed it through my Earlex 5500 (both the primer and the poly). -- Matt, Arizona, http://www.reintroducing.com |
#3 posted 01-06-2013 04:31 PM |
I’ve used General Finishes milk paint w/ good results on MDF. -- Bondo Gaposis |
#4 posted 01-06-2013 04:39 PM |
another tip. If any cut edges, bull nose, “end grain” will be exposed seal it first with a light coat of drywall compound. Just use your finger to rub it in then sand it smooth. It makes a nice finish. -- Dan, Naperville IL, I.G.N. |
#5 posted 01-06-2013 04:58 PM |
Murphy bed for the office. Good grief, don’t let HR know that you’re doing this! -- - Crud. Go tell your mother that I need a Band-aid. |
#6 posted 01-06-2013 05:43 PM |
making a murphy bed from MDF ?……… poor choice as it doesn’t stand up to the stress/force of the hardware. -- "Good artists borrow, great artists steal”…..Picasso |
#7 posted 01-06-2013 05:56 PM |
I just finished a murphy bed a few months ago. I would not use MDF. As moron says I don’t think it would stand up to the stress of the hardware. -- Bruce, Boise, ID |
#8 posted 01-06-2013 07:29 PM |
Thanks for the responses. I was not specific enough. I was only going to use the MDF for the surround built in, shelves, parts of the desk, and cabinet. Maybe I should just use plywood for it all? |
#9 posted 01-06-2013 07:40 PM |
Plywood is stiffer in spans like shelves, holds most fasteners You can get some of MDF’s stability benefits in a plywood Using MDF will save you some money and eliminate |
#10 posted 01-06-2013 10:42 PM |
I would personally use plywood. -- He who dies with the most tools... dies with the emptiest wallet. |
#11 posted 01-07-2013 01:55 AM |
I just finished SMS cabinets for my shop. I used MDF as the panel inside all of my doors…. I primed it, sanded it flat with high grit paper, did a few coats of good white paint with flotrol and thinned at 75/25, then brushed on some poly thinned to 75/25….. It cam out very flat and smooth…. I lightly sanded between poly coats, but only to get out dust and freakin cat hairs hat no matter how I tried could not keep then all out! Itf you can’t spray I would try that…. Be sure to prime well and seal MDF end grain…. |
#12 posted 01-07-2013 03:34 AM |
try throwing the cat outside confirmats and associated hardware, as Lorne said, if properly installed into MDF, will last longer then you will -- "Good artists borrow, great artists steal”…..Picasso |
#13 posted 01-07-2013 07:21 AM |
If you do decide to use MDF, I’ve found that with zinsser BIN primer, sealing the edges isn’t necessary. Just prime, lightly sand with 320, another coat of primer, lightly sand and you’re good. -- He who dies with the most tools... dies with the emptiest wallet. |
#14 posted 01-09-2013 03:18 AM |
+1 to what NiteWalker said. I didn’t seal edges and did two coats exactly as he stated and it came out perfect. -- Matt, Arizona, http://www.reintroducing.com |
#15 posted 01-09-2013 03:40 AM |
Like others have said, I have also had great success without sealing the edges. The key is a good primer. (zinsser, Stix, etc..) As far as the paint goes, I’m a big fan of the Benjamin Moore Advance. It flattens beautifly and once fully cured, it is very hard/durable. The trick to it is not to apply heavy coats. If you put it on too heavy you can end up with some nasty sags. |
Forum | Topics |
Woodworking Skill Share
12031 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4905 |
6695 |
28061 |
CNC Woodworking
212 |
Hand Tools
5411 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4757 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
