| Forum topic by Tbowen | posted 134 days ago | 681 views | 0 times favorited | 11 replies | ![]() |
134 days ago |
Topic tags/keywords: question scroll saw scrollworking OK, i just got my first scroll saw and love it! i have made a few projects on it like, letters and a stick man, and a wheel…. also how do you get that paper to stay, and when you are finished how do you get that papper off with out leaving a mark??? also i have the 5” L blade ….what brand of blades are the best? and what TPI (teeth per inch) is better for soft wood? -- don't out smart your common sense |
11 replies so far
#1 posted 134 days ago |
Check out Sheila Landrys classes here on Lumber Jocks she gives incrediably good advice. You might also try Steve goods site scroll saw workshop. I am also very new to scrolling and both of these sites helped me a lot. |
#2 posted 134 days ago |
There are as many ways to make, and attach patterns as there are scroll saws. Here is my suggestion based on what I do though. I have read in numerous places about gluing patterns directly to wood. I tried that several times and had nothing but trouble with it. No matter what technique I tried, I always wound up with either a patter that would not stay on or a sticky, gooey mess to clean up afterwards. With the masking tape being applied to the wood first, I’ve never had an issue with patterns coming off, or removing them afterwards. The only issue I have had was when I used cheap tape and left it on the wood for a week. Even then though, it still came off. I just had to be a little more careful with it. |
#3 posted 134 days ago |
As for blades, I find that to be a matter of personal choice. While many scrollers will use many of the same blades, if you ask around enough, there are just as many scrollers that will tell you they use something completely different. |
#4 posted 134 days ago |
thank you all for the info!!! thank yall very much :-) this helps ALOT -- don't out smart your common sense |
#5 posted 134 days ago |
I forgot to mention Steve Goode’s site. It is a vaulable source for new, and experienced scrollers alike. Go to Scroll Saw Workshop. He offeres plenty of free, downloadable patterns. Most are easy enough for beginners, but interesting enough for experienced scrollers. |
#6 posted 134 days ago |
-william-.. man, THANK YOU SO MUCH!! very big help :-) i looked at your work on your site, AMAZING job.. i hope i can make some projects like you have some day…very big help thank you sooo much! :) -- don't out smart your common sense |
#7 posted 134 days ago |
americancankuck—- also thank you vey much for the link and for the comment back!! :) it helped alot, Thank you all -- don't out smart your common sense |
#8 posted 134 days ago |
You have received some excellent advice. The only addition I would make is that I sometimes add clear packing tape over the pattern if I am cutting a very hard wood as this helps lubricate the blade and prevent burning. You might also check our Free4all Scroll Saw Patterns. They are a great group of people. -- Kepy |
#9 posted 134 days ago |
-kepy- ok, ill check that out.. thank you and thats a good idea to prevent burning…thank you -- don't out smart your common sense |
#10 posted 133 days ago |
With a little practice Bruce, you can build anything that I can. |
#11 posted 129 days ago |
If you get glue on the wood, Lacquer thinner will take it off. -- Emmett, from Georgia |
| Forum | Topics |
Woodworking Skill Share
8788 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1528 |
3545 |
15760 |
Hand Tools
2033 |
Jigs & Fixtures
494 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6154 |
