Blotching maple
Forum topic by Trevor Roth posted 01-06-2013 10:22 AM 1209 views 0 times favorited 16 replies Add to Favorites Watch
View Trevor Roth's profile
Trevor Roth
94 posts in 2342 days
01-06-2013 10:22 AM
So I have a problem. I have never worked with maple before and I recently built some new kitchen cabinets out of maple and the stained them with watco walnut danish oil with horrible results after it dryed. What is my best bet to fix it now without sanding it off? I was thinking on getting some general finish gel stain and seeing if I can even it out. Any advice would be most appreciative.
16 replies so far
View CharlesNeil's profile
CharlesNeil
2468 posts in 4107 days
#1 posted 01-06-2013 02:21 PM
I am assuming you used a colored oil, correct ?
a picture would help alot
Trevor Roth
#2 posted 01-06-2013 03:52 PM
Yes it was a dark walnut,
View JesseTutt's profile
JesseTutt
854 posts in 2347 days
#3 posted 01-06-2013 03:54 PM
Sanding or scraping would be best. I have always wanted to try some form of paint stripper.
Trevor Roth
#4 posted 01-06-2013 03:57 PM
That wont be possible for the side panels its thin veneer and I already contact cemented them to the carcasses.
CharlesNeil
#5 posted 01-06-2013 03:59 PM
ouch, try wiping it with some lacquer thinner, to see if any of it can be pulled out, lacquer thimnner is pretty strong, but evaporates fast, wear protection its also quite flammable, I am concerned that wiping it with mineral spirits would actually cause it go deeper, not sure it will help , but getting it lighter would help alot, then try the gel stain,
Trevor Roth
#6 posted 01-06-2013 04:05 PM
Thanks, in hindsight I wish I would have read up on maple before hand. I am used to working with oak.
View pwalter's profile
pwalter
79 posts in 2821 days
#7 posted 01-06-2013 04:10 PM
Hey Troth, I just did two shelves out of maple, and the customer wanted them to have a deep dark brown color. I had good luck applying water first then using a dye. It actually came out pretty well. I also learned, the darker blotches can be scrubbed with a damp rag and it will pick up some of the dye and make it a little lighter. BTW I am not a professional finisher so take my advice with a grain of salt.
CharlesNeil
#8 posted 01-06-2013 04:19 PM
pwalter , your correct, if using a water base colorant but the issue here is we have an oil base and water will not pull the oil .
Troth , did you do all of the cabinets ? Also , how long has it been on ?
View bondogaposis's profile
bondogaposis
5150 posts in 2587 days
#9 posted 01-06-2013 04:39 PM
You’ve got some sanding in your future I’m afraid. About the only real fix for it.
-- Bondo Gaposis
View Dusty56's profile
Dusty56
11830 posts in 3924 days
#10 posted 01-06-2013 04:54 PM
I never understood the concept of trying to make Maple look like Cherry or Walnut or any other dark wood. Easiest thing to do is start with the type of wood that you want it to end up looking like : )
This is Mother Natures way of rebelling against us for trying to ruin her beautiful handiwork.
You might as well paint it at this point.
Trevor Roth
#11 posted 01-06-2013 08:00 PM
I went over it with a thick coat of gel stain let it sit a little longer before I wiped it off and it turned out pretty good so far. Yes all the cabinets were stained yesterday afternoon. Hopefully it dries how it looks now. Thanks
CharlesNeil
#12 posted 01-06-2013 11:16 PM
much better ,
much better , I was concerned
View waho6o9's profile
waho6o9
8539 posts in 2813 days
#13 posted 01-06-2013 11:52 PM
Well Troth, looks like you saved it, very good.
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2591 days
#14 posted 01-07-2013 12:59 AM
To avoid blotching in the future try a pre-stain conditioner, like the ones produced by minwax and cabot. I prefer the cabot as it seems to work, better, but don’t let the conditioner dry completely you want it to block the stain from penetrating too far into the wood which is what causes the blotching.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
Trevor Roth
#15 posted 01-07-2013 04:41 AM
Ya im glad it worked out I wouldnt have been able to sand the stain out of the ply without going through the veneer. Here are some before and after.
