| Forum topic by Purrmaster | posted 135 days ago | 454 views | 0 times favorited | 6 replies | ![]() |
135 days ago |
I’ve got some Power Twist link belt I’d like to use. But the belt I would be replacing is a ribbed rubber belt. The pulley is ribbed and does not have…. sides. I think they are called flanges. There are grooves cut into the pulley and the ribs on the belt fit into them. I tried a quick test and the link belt didn’t want to stay on. Can you replace a ribbed belt with a link belt? |
#1 posted 135 days ago |
The ribbed belts are called serpentine belts. It sounds like you already have your answer though. -- -- Rick M. |
#2 posted 135 days ago |
No, you can’t. Not without replacing the pulleys too. -- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain |
#3 posted 134 days ago |
Linked belts don’t do much on some machines in terms of vibration reduction so I would make sure it’s really worth it before you start changing pulleys etc. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#4 posted 134 days ago |
Unless you’re suffering from extreme vibration caused by the ribbed belt and pulleys (highly unlikely) , you have nothing to gain by changing them : ) The Power Twist is for V-belt pulleys. -- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did. |
#5 posted 133 days ago |
Changing pulleys isn’t going to happen. I just happened to have some link belt on hand. I was under the impression that a link belt reduces vibration and gives a smoother operation to whatever is being driven. I slapped a link belt on my Harbor Freight jointer and it did seem to improve things. |
#6 posted 133 days ago |
A link belt will offer smoother operation than a v-belt that’s got problems, but it won’t do much for a belt that’s performing well. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1530 |
3547 |
15767 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6156 |
